Hot Rods carb banjo fitting with female end
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Jan 29, 2021.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    I can't seem to find a banjo fitting for my holley 4 barrel that allows a run of the mill parts store 5/16 or 3/8 fuel line to just screw into the end of it. Just the simple end for a double flare line to hook to. I don't want a rubber line going to my carb from the fuel pump.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    You don’t want a banjo, then.
    https://www.holley.com/products/fue...ents/fittings_fuel_lines_and_gauges/fittings/
    Lots of other options, probably you want one of the flare fittings. Threaded would be difficult to install.
    egads likes this.
  3. 24riverview
    24riverview
  4. You said banjo?
    Banjo.JPG :D:D:D:D:D
    jimmy six likes this.
  5. Different carb, but on Edelbrock I have, it used a smooth fitting with a barb on end for hose. I cut the barb off(right at its edge) then used compression type steel line to run to fuel pump. Because the Edelbrock points straight out, I used a 90 degree compression fitting to point the line to the front and to pump. Something like this one, as I used stainless hard line. Swagelok-90-Degree-Elbow-Union-1.jpg
  6. Last edited: Jan 30, 2021
  7. flying53gmc
    flying53gmc
    from M-boro, TN
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    That says its a 1"-20 carb thread , single feed holley is 9/16"-24 IIRC....
    I'll get out to the garage later , I might have something that will work
  9. squirrel
    Looks to me like a rather strange way to do carb plumbing. Post a picture of what you're doing, so I can understand why you'd want such a thing? Maybe to save making a 90 degree bend in a piece of tubing?
    warhorseracing likes this.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you want a 90° turn off the carb , that's a no- go.
  11. The 1” is the big adapter piece that goes into the carb, the banjo bolt is smaller. But even if that doesn’t work you might be able to use the banjo itself with a Holley banjo bolt.
  12. flying53gmc
    flying53gmc
    from M-boro, TN
    B331B8A2-B790-4E05-BCAC-95E4A51E9CCF.jpeg 3EF782B7-C31C-41C5-B122-87413940FAA7.jpeg
  13. squirrel
  14. flying53gmc
    flying53gmc
    from M-boro, TN
    Thanks Squirrel, I should be able to make that work. Just trying to make it as tidy as possible. That will be a tight bend to make look good.
  15. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    I've also had to have a fitting like that, due to using a drop down air filter, on a low hood car. I used rubber, but the IFF adapter to banjo is a much better idea!
