Technical Cant access spark plug help
Discussion in 'Traditional Hot Rods' started by lawdogg1, Sep 14, 2021.
  1. lawdogg1
    lawdogg1
    Ok guys I need some ideas or some help here. I have a 56 f100 the the y block 272 with the ram horn headers from mummert. I am trying to change the spark plugs but I am having a very hard time! There is not much clearance for the socket between the header and plug. So I am unable to remove them. Is my only option to remove the headers then remove the plugs? Or does anyone have any ideas or ran into this problem. Thank you.
  2. Kiwi 4d
    Kiwi 4d
    Not sure but we have the original rams horns on a couple of cars , one fenderless hiboy 28 A and a 49 shoe box coupe, which is clearly more of a reach, and with the originals its not a straight shot but definitely doable . Can you use a thin walled socket??
    Deuces and lothiandon1940 like this.
  3. lawdogg1
    lawdogg1
    I have tried just about every socket I could find even thin and it's still just shy of being able to clear. I'm guessing I'll have to remove the ram horns to access them
  4. Kiwi 4d
    Kiwi 4d
    Cant see my sons rams horns as they are away being coated , will try to take a picture of our 49 coupe tomorrow in daylight.
    lothiandon1940 likes this.
  5. XXL__
    XXL__
    If you end up taking them off, clearance them with a die grinder before you reinstall them.
    Roger Loupias, 51 BIRD, egads and 2 others like this.
  6. Kiwi 4d
    Kiwi 4d
    I know this doesn’t really help , but these are original Y block rams horns , #1 #2 no real issues . It would seem Mummerts are different casting . Perhaps contact John Mummert. Would a 1/4” socket work rather than 3/8?
    962267CA-EC00-4A06-BF32-A212FDC47B7D.jpeg 1606B86B-F85F-49B7-886A-3FA020C173F6.jpeg
    5window and lothiandon1940 like this.
  7. Deuces
    Deuces
    from Michigan
    Get a cheap spark plug socket and grind the o.d. with a grinding wheel to gain clearance....
    Make sure you have safety glasses on your mug.....;)
    fauj, 5window, Bob Lowry and 2 others like this.
  8. G-son
    G-son
    from Sweden
    Make a tool that fits. Perhaps shorten the socket, and grab the hex head on it with a suitable tool?
    Deuces likes this.
  9. egads
    egads
    These work great, not cheap but they work.--https://sdparts.com/i-21050945-powerhouse-products-pow301155-socket-13-16-spark-plug-2-pcs-w-case.html?gclid=EAIaIQobChMI28Pt9euA8wIVTsvICh0QoQ6OEAQYASABEgKwMfD_BwE F142423846.jpg
    fauj, loudbang, ottoman and 3 others like this.
  10. Mr48chev
    IMG_2570.JPG IMG_2575 (2).JPG Brigs and stratton plug socket.jpg My old SnapOn swivel spark plug socket is pretty short and reaches in most hard to get to spots pretty well.
    Otherwise it is probably make one to fit the application.
    It seems that we all have one of those old small engine spark plug sockets in the junk drawer until we need to use it but you can still find them easily enough if you don't have one and it would be simple to cut to fit and then either use a wrench on it or weld something to it for a handle for a special tool
    Photo curtesy of this kind Ebay seller Machinerypowerinc
    eBay item number:
    283520701488
    Just make sure that you get one that is 13/16.
    fauj likes this.
  11. olscrounger
    olscrounger
    ^^^ this--I have one of those for small engines cut and modified for this type of situation-cheap and easy
    fauj likes this.
  12. Motorcycle thin wall stamped socket...
  13. choptop40
    choptop40
    there you go..another Hamb rescue...
