Hot Rods Can you successfully run a brake booster with a 671 blower
Discussion in 'The Hokey Ass Message Board' started by ratman, Oct 27, 2018.
  1. ratman
    ratman
    I haven't been on the Hamb for a while. Life got busy and a job change dictated not a lot of spare time.
    I am currently thrashing on my current build and am undecided on whether or not to run a brake booster.
    My question is can you successfully run a brake booster with a blower. I do have a vacuum port at the base of the carb.
    Thanks in advance for your help.
    Deuces, mad mikey and chryslerfan55 like this.
  2. Only if you run a 'vacuum reservoir' would be my guess. You have basically two on a conventional application; the booster itself and the volume of the intake manifold plenum. You're lacking the latter one. Another choice may be an electric vacuum pump as used on a lot of diesels. I'm sure there's a way to do it, given factory supercharged cars, but it may take more paraphernalia than you have room for...
  3. Kerrynzl
    Kerrynzl
    Seeing that you're in NZ, grab an alternator off a Jap Diesel with the vacuum pump on the back of it.
    They're good enough to haul-up a diesel truck. [and cheap and plentiful]
  4. ratman
    ratman
    Thanks for the suggestion I will see what's out there and what size they are.
    Sent from my SM-G930F using The H.A.M.B. mobile app
  5. ratman
    ratman
    I had not thought of that. I had a quick look on Trade Me and found this. This could be a good solution thanks. 20181028_144558.jpeg
  6. Slick set-up… You may want to check out how these were plumbed in an OEM application, you may still need a reservoir can.
  7. ratman
    ratman
    I will put in a reservoir can. I can fabricate one up to suit available space.
    Thanks for the help.
  8. Kerrynzl
    Kerrynzl
    On a Mitsy Pajero, and Nissan Mistral the vacuum is plumbed direct to the booster.
    They have enough vacuum to "suck start a Harley"
    They need an oil feed and drain plumbed in [similar to turbos]
    gimpyshotrods and ratman like this.
  9. Kerrynzl
    Kerrynzl
    That's what I'm thinking [the internal regulated Alts are easy to hook up]
    Go for a sunday shopping trip to "pick a part" with your phone camera. Some are LH and some RH
