Can you help me identify this bracket?
Discussion in 'The Hokey Ass Message Board' started by Psychoholic, Nov 28, 2009.
  1. Psychoholic
    Psychoholic
    My friend Tony and I sat there for a good 10 minutes discussing what we thought this bracket to be and came up with exactly squat.
    The car is a '51 buick with a 320 straight 8, no air conditioning (no controls for it - has under seat heater), does not have power steering. The generator is below the bracket.
    Thanks in advance!
    Chris
  2. randydupree
    randydupree
    from archer fl
    it supports the air filter housing.
  3. Psychoholic
    Psychoholic
    That's what I figured the top one was, it's the one in the front of the motor we can't figure out. There is also a 2 groove pulley on the crank that only
    goes to the generator.
  4. Squablow
    Squablow
    My Dad's 52 Roadmaster has a 320 with a power steering pump where that big bracket is, are you sure this is the original engine in the car? Original steering box too?
  5. Brandy
    Brandy
    from Texas
    You know, that's some shit when every pic you google, PLUS every pic I've ever taken.......are of the other damn side of the engine.
    But I know why, it's the prettier side.
  6. I agree with the power steering suggestion.. the 50 buick im working on for a friend right now has the upper bracket for the air cleaner but not the lower one or double groove pully and its manual steering. so power steering seems the right option.
  7. Psychoholic
    Psychoholic
    I'll take another look under the car at the steering box and see - I'm not 100% confident that it is the original motor, but that seems like something you'd take off when you swapped motors?
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Why? It's not hurting anything, and if the engine was swapped from another into this car, it was probably done way before anyone gave a shit about the fact that it might not "look right".
  9. Psychoholic
    Psychoholic
    I'm not concerned with it looking right or not (trust me, you should see the floorboards - 'functional' yes, pretty, no.) - if it has no purpose it may be the new mount for a 12V alternator. =)
    The engine swap question would make sure I buy the right parts it is a different motor than I think is in it (like the smaller engine has been swapped in place of the 320 or something like that).
