Technical Can you guyz help me ID this Bellhousing ??? Mopar ???
Discussion in 'The Hokey Ass Message Board' started by hellerlj, Jan 29, 2016.
  1. hellerlj
    hellerlj
    from Minnesota
    Sorry about the fuzzy photo...
    The part number on it is 1736436
    I "THINK" it is Mopar of some sorts
    The big hole makes me think automatic ?????
    I know there is someone here that knows more them me
    And Help or Input is much appreciated....THANKS
  2. it looks like a mid 50's mopar a488 auto bell housing, should fit early hemi and poly motors I believe.
  3. moefuzz
    moefuzz
    It does look like early Hemi.
  4. Hnstray
    Hnstray
    from Quincy, IL
    That loooong input only applies to semi-auto and full manual trans. The fully automatic, Powerflite and Torqueflite, have 'normal' length bells.
    I agree this housing is for a Mopar automatic, but I do not know the specific application.
    Maybe 73RR would have the answer.
    Ray
  5. The engine block side bolt pattern screams B/RB (350, 361, 383, 413. 426, 440) and not A or early hemi/poly engine. The alignment dowel locations and starter location are the giveaways. The casting number range makes me think its for 1958 or so application. The long crankshaft flange stick-out dimension on the 62 and earlier engines requires the deeper bellhousing depth. For confirmation, try it out on a 440 engine.
  6. Big_John
    Big_John
    from Upstate NY
  7. squirrel
    I concur with the B/RB id.
  8. hellerlj
    hellerlj
    from Minnesota
    THANKS EVERYONE FOR THEIR INPUT....I THINK
    WE GOT IT FIGURED OUT...OR AT LEAST CLOSE,
    AND THAT WILL DO....
    I APPRECIATE EVERYONE'S TIME AND EXPERTISE
