Hi All, I have a 23" nostolgia shifter, and I mis measured, and it hits the seat in drive no matter how I adjust it. Can I cange out to a 16" shift arm or do I have to replace the whole unit, including remounting the freakin thing? I looked on the website, and I do not see any options for just buying the shift arm, so I thought I would ask all of you if you have any experience for me? Thanks,
Their easy to get along with, give them a call. I would think you could cut down the cable and just switch parts. You might look to make a trade here in the want ad section.
I do believe all their shift shafts will interchange. if you go shorter or longer you will have to change or modify the internal cable for the detent knob. Or...fill up your hole and remount it where it needs to be.
I attended the open house at Lokar during the Nats South in Knoxville,Tenn. last week and talked to them about a problem I have with their low emergency brake. I explained that the button to release the cable at the end of the handle broke and the button and spring let go,,, the gent I talked to said no problem,,,take it out and send it to them and it would be replaced or repaired at no charge to me,,,, HRP
A 16" Nostalgia Chrome shift lever replacement kit from Lokar is part number: S-68147 $98.99 from Summit
Thanks guys....I guess this was an easy one to solve, now who wants to come and build a floor for the truck this weekend???? Seriously, I took the old arm off this evening, and measured twice, the 16" will look great.
