can I remove my dash?
Discussion in 'The Hokey Ass Message Board' started by Firecracker, Jun 24, 2009.
  1. Firecracker
    Firecracker
    I'm sure that this might be a stupid question, but I've been looking at the dash in my 53 chevy and I was wondering if there was a way to take it out so that I can paint it?
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Car or truck? Trucks are welded in. Dunno about cars
  3. Firecracker
    Firecracker
    Oh sorry, It's a car
  4. Big Nick
    Big Nick
    I think cars are welded in also. My buddy painted his in the car.
  5. jville_hot_skater
    jville_hot_skater
    from jville
    look under the dash to see if its bolted or welded on...if its bolted, then go on a paint it.
  6. fatrhino
    fatrhino
    my '50 is welded in, so no go unless you cut it out and weld it back in (which would probably ruin the nice paint that you removed it to spray on)
  7. 49ratfink
    49ratfink
  8. Firecracker
    Firecracker
    I haven't been able to find any bolts, so i'm guessing that it's welded in. I didn't know if there was anyway to get it out. I've seen some really nice dashes in 53 and 54 chevy, so how are you guys painting them? Is it best to strip it in the car and then just use a touch up gun?
  9. Slag Kustom
    Slag Kustom
    take the dash all apart,window out. tape every thing up and paint like any other part.
  10. oilslinger53
    oilslinger53
    from covina CA
    They dont come out without lots of cutting. You gotta paint it in the car.
  11. Firecracker
    Firecracker
    Thats what I was thinking that I would have to do, but I was trying to et around having to take the glass out.
  12. Shaggy
    Shaggy
    from Sultan, WA
    I brush painted my 64 el camino dash, dont laugh, just wet sanded and buffed it out afterwards and it looked near perfect, until it got bent when i got t-boned
  13. Tcoupe
    Tcoupe
    I just painted the dash in my 53...in the car with the windshield in place, used a smaller touch up type gun on it.
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Once the dash is stripped, before you paint it, here's a tip;
    Spray bomb the back side of the dash in white. If you ever have to troubleshoot wiring, etc. under the dash down the road, you'll have an easy on the eyes white backgroung for all your wiring, etc.
  15. 454_4_ON_THE_FLOOR
    454_4_ON_THE_FLOOR
    from Selden, TX
    I wish you could unbolt the things, it would be so much easier to clean and sand and paint. As far as I know they're all welded though.
  16. skyrodder
    skyrodder
    what you could do , is cut it out and weld some tabs inside of it so you can bolt it back on when your done painting it chroming etc.......
  17. Von Dago
    Von Dago
    from New Jersey
    Hot Rods Ta Hell, that is one great idea.
  18. Firecracker
    Firecracker
    that sounds like a great idea.
    How hard is it to get the gushes and chrome to come out and when you get the gauges out, can the be taken apart and cleaned?
  19. Chevy dashes are welded 1949 through 1960 at least. If I have to cut one out I try to cut under the garnish trim.
    Interestingly not all GM dashes in the same body styles are welded. For instance 59-60 Pontiac bolt in, and they're two pieces (a top and a bottom). The Chevy the bottom is bolted but the top is welded - and it's all one piece.
  20. The Gambler
    The Gambler
    GREAT tip!!!
  21. EV34
    EV34
    thats a bitchin idea
  22. mrconcdid
    mrconcdid
    from Florida
    Im trying the same thing in the same car 53 chevy, my dash is rotted out really bad from a leaking front windshield. I see it is spot welded in on the right and left sides, there are also 2 rod style braces running to the firewall, the dash looks like it goes into the front windshield channel. does it? i would like to leave the glass in for now and just remove the dash to rebuild it.
    So my question is really, if I drill out the spot welds and remove the rod braces will the dash come out or does the window also have to come out?. thanks
