Can Bondo that has froze still be used?
Discussion in 'The Hokey Ass Message Board' started by BlueOvalCertified, Jan 12, 2011.
  1. BlueOvalCertified
    BlueOvalCertified
    from Minnesota
    Can it still be used?
  2. BISHOP
    BISHOP
    Put a heat lamp on it and it will soften up. It really cant freeze.
  3. PhilJohnson
    PhilJohnson
    Heh, to some of us who make it on less than $200 bucks a week it's a good question. I have some Bondo that froze too so I am curious to know the answer.
  4. darkk
    darkk
    I wouldn't...yes I'm a body man.....
  5. Jalopy Jim
    Jalopy Jim
    Should say on the can whither it can freeze or not.
  6. Master of None
    Master of None
    Hardener froze too? I'd get a new tube of it and try it.
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Let it thaw and if nots hard use it ,But mix it up with a beater .If its hard ditch it .
  8. Hank
    Hank
    from Wisconsin
    Should be fine once it's thawed. You might have to mix it if it's been sitting for a long time. The solids tend to settle to tht bottom.
  9. Stu D Baker
    Stu D Baker
    from Illinois
    What Hank said. Try not to whip it while mixing it. You don't want to introduce air into the filler. Stu
  10. Mix up a sample and let it cure! You should have your answer in a few minutes. It's not like it's going to lose "water resistance" (doesn't have any) or anything!
  11. BlueOvalCertified
    BlueOvalCertified
    from Minnesota
    Hey thanks! I am going to try a test batch, like rec.
  12. CR1193
    CR1193
    from Tennessee
    "I wouldn't...yes I'm a body man....." X-10
    Not a professional body man, but I've done my own for years.
    To me it's not worth the gamble, you will spend alot of time and money on top of the bondo, so why chance it!!!!!!!!!!
  13. HELLBILLY
    HELLBILLY
    Is it old? Been sitting outside since last year? Or was in in the car overnight?
    I will say this, take it how you want.
    My Paint store orders were shipped from a warehouse dist in Ohio (PBE Jobbers), on the truck for days, Ive got cases of Bondo before that were froze solid as a rock.
    And if you think it dont get that cold sitting on trucks for a few days .... well the froze and busted Meg. 3M etc) compounds says it does.
    I would be more afraid of OLD Bondo that a can that had been froze.
  14. It gets frozen in shipping all the time. Up here it can be on a train or a truck for a week in -40 degree weather. More problems will occur from age than freezing.
  15. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Think about what it would take keeping the stuff from freezing during shipment....heated trucks, etc. I would use it....
  16. overspray
    overspray
    The bondo will be OK if frozen. Polyester resin keeps very well in a refridgerator, for long term storage. The hardner may not be good after extreme cold. Hardner doesn't freeze the same as water. If it's bad it will usually separate into a runny liquid and a grainy paste instead of a smoothe consistent paste. Knead the hardner tube with your fingers to make sure it is mixed. Squeeze out some and check to see if it looks as described. If your are still not sure mix a test batch and see if it still cures the bondo. Bondo is still very cheap compared to paint and primer, and it is the "foundation". When in doubt--throw it out.
    Make sure both components-bondo and hardner-are both at room temperature before using, and always be sure the metal and air temps are in the correct range for the bondo to cure evenly and completely.
    Bondo 101 TECH THREAD:
    http://www.jalopyjournal.com/forum/showthread.php?t=8318&showall=1
  17. Francisco Plumbero
    Francisco Plumbero
    from il.
    Toss it and Switch to rage, you can either buy paper or rage.
  18. temper_mental
    temper_mental
    from Texas
    Stop storing it in the freezer.
  19. Noland
    Noland
    Very true, Bondos garbage. I actually use evercoat chroma-Lite. It is that same yellow gold color as rage gold and works just the same,just its half the price. It comes in a plain white can. doesnt eat up the paper
  20. 383 240z
    383 240z
    Im pretty sure there is an 1-800 number on that can call them, they would know. Keith
  21. BigNick1959
    BigNick1959
    I would think that during the delivery process in a box car or a semi trailer (which arent heated) it gets frozen before it gets to our local vender. We all don't live in California ya know. I say, heat it up, mix it up and use it!
  22. Polyester body fillers consist of polyester resin and talc like fillers. polyester resin has a shelf life due to promoted resin, styrene evaporation. The fillers get stiff in the cold but do not kick off.However, old body filler will get stiff and unusable as promoted resin(cobalt added at manufacturer) will become useless if too old.It is more expensive to buy the smaller cans but in the long run better economy if you have to throw out a half gallon of old filler.
  23. voodoo1
    voodoo1
    Put it in the house for a day and let it warm up. Stir it with a heavy duty stir stick or big screw driver, don't whip it up and get a bunch of air in it. Just make sure the resin is mixed in and it looks consistant. Make sure it gets put up high and out of reach of any young ones. Mike
  24. Crankhole
    Crankhole
    Its's gonna freeze again after you spread it on your car. I can't imagine it being a problem.
