Technical Can anyone tell me what these holes are for
Discussion in 'Traditional Hot Rods' started by Hotrod31A, Aug 6, 2022.
  1. Hotrod31A
    Hotrod31A
    31 Model A subfloor extensions. What are the embossed holes in the red circle used for?? 0698432D-EF17-4451-8120-12568A877AF4.jpeg
    Stogy likes this.
  2. 28rpu
    28rpu
    It's been awhile since I did an A but might be for the angled metal toe board pieces that attach there and to the fire wall.
    Stogy likes this.
  3. Hotrod31A
    Hotrod31A
    Thought so too but they don’t match up 1CB60845-531C-48DE-B0E7-C40E8BAC1620.jpeg
    Stogy likes this.
  4. gary macdonald
    gary macdonald
    I think your plate has been cut .
    19Eddy30 and Stogy like this.
  5. tomcat11
    tomcat11
    I wondered the same thing. Maybe they were used for some type of factory assembly tooling? I'll probably get some plugs for mine. Maybe a call to Snyder's or Bert's would produce an answer.
    Hotrod31A likes this.
  6. Hotrod31A
    Hotrod31A
    They’re brand new repop parts and toepiece has to be where it is to match up the floor seam on firewall. Maybe these don’t match the originals?
    No biggie, just curious what they are, my floor was a channeled hack job and have nothing to work off other than internet wisdom.
    warbird1 likes this.
  7. Hotrod31A
    Hotrod31A
    Thanks Man! Was scratching my head a little there thinking I screwed up.
  8. alchemy
    alchemy
    Screws to hold the wood block in place?
  9. Hotrod31A
    Hotrod31A
    Hmmm that might be the winner! The two holes behind them are the mounting block bolt holes…
    Stogy likes this.
  10. tomcat11
    tomcat11
    They look just like my repop's from Brookville. I think they match the originals real well. I don't think they were for any wood.
    In another thread you asked about a tranny hump. I just put my mock up engine (327/TH350) in and I do have a slight interference right at the joint between toe board piece and the front floor piece. I made mine two pieces with a flange but I see yours in all one piece. I'm now working on a small hump. I'm building my car to accommodate other transmissions in case I want to change to a 4 speed or run my B&M Turbo Clutch. I'm almost certain you'll be doing some sort of hump.
    pic from here on the hamb Should help with the brace.
    My memory isn’t the best for model As. But isn’t there a block of wood in that area under the sub rail?
    I could be wrong.
    For some reason I thought the roadster had a block of wood.
    gary macdonald likes this.
  12. tomcat11
    tomcat11
    You might be right! I didn't think about under the sub-rail. Now that you mention it I think maybe the original A's did have some wood between the body and frame.
  13. Hotrod31A
    Hotrod31A
    Yep they mount to the frame with 6 wood blocks approximately under the cross sills
  14. Hotrod31A
    Hotrod31A
    Hey post a pic when you’re done with the hump. I may want to follow your lead
  15. The37Kid
    The37Kid
    The front wood blocks are held in place with two wood screws, the blocks are an odd shape and need the screws to hold them in place on the assembly line. The other wood blocks were a tight fit in the channels.
    Bob
    dmar836, warbird1 and Hotrod31A like this.
  16. Hotrod31A
    Hotrod31A
    Thanks Bob you made me a little smarter today. Learned sumpthin!!
    The37Kid likes this.
  17. tomcat11
    tomcat11
    Will do. I ordered the material and am working out the details. These cars are very small. Packaging everything (pedals etc.) with good driver ergonomics has been a nice challenge. Hopefully you'll get your frame soon and open the next can of worms!
  18. Hotrod31A
    Hotrod31A
    Yep I hope ditching the channeled floor and gaining back the 4” of space will help. Couldn’t drive it before as the brake and gas were jammed under the steering column. It sucked with my size 13s.
  19. 19Eddy30
    19Eddy30
    from VA
    If that part is now being reproduced/made Now . Must be in last 10ish years
    ( subframe to firewall)
    The op pic , For the 30-31 its not made correct to originals , those bolt hole are for the original design FoMoCo
    Todur,roaster ,coupe & Believe 3 holes triangular pattern may be 2 thoe on sub rail & 3 on firewall, I used a BV new subrail then all other original Ford .
    Bolt thread I'm sure was also #12 screw thread, Original ones where hard to find in good shape ( brace) 10 yrs ago,
    Most just would bend up a metal brace & weld in .
    Im sure someone here has a pic with original firewall and subrail & brace, if not i know on the Barn
  20. 19Eddy30
    19Eddy30
    from VA
    These are originals , not my pic,
    my post above might be completely wrong about Bolt in & screw holes,
    Been over 10 years , & im not near roaster to verify , maybe spot weld to subrail then Rivets to fire wall , & 2 bolt holes in subrail, I'm question about what I remember for & sold a compleat original frame & body with original wood.
    Just remembered the screw holes where there to hold the subrail Extensions wood in place,
    Until body was sat on frame
  21. tomcat11
    tomcat11
    Here's another picture of an original part. They were fastened with 3 rivots.
  22. Hotrod31A
    Hotrod31A
    this piece was riveted to my original firewall with I think were 3 rivets.
  23. Grant Clemens
    Grant Clemens
    from Montana
  24. Grant Clemens
    Grant Clemens
    from Montana
    My 1930 tudor has never been apart. This body has never been off of the frame. As you can see in the picture there were two flat head straight slot screws to hold the wood block.
  25. Hotrod31A
    Hotrod31A
    Awesome thank you for the info and pics!
  26. choptop40
    choptop40
    They might be the holes in my head....
  27. alchemy
    alchemy
    Called it!
