Can anyone identify this horn?
Discussion in 'The Hokey Ass Message Board' started by 40Ford!!, Apr 4, 2010.
  1. I'm hoping someone can ID this horn. Also, what does the large flathead screw in the center do if anything?
  2. dorf
    dorf
    from ohio
    the screw may adjust the tone or be a mounting point
  3. Yeah, I think it may adjust the tone. Any idea what year it's from? Or what vehicle(s) it went on.
  4. playtag
    playtag
    Not sure what year,would assume 6 volt.The screw most likely adjust the diaphram inside this will make a difference in the noise but as the horn vibrates the diaphram has a small (for lack of the correct term) nipple that rubs against a gear the vibrates the diaphram through use the nipple wears down.and they would have to be adjusted to function properly
  5. 29nash
    29nash
    from colorado
    loosen jam nut,
    With that pitting it might not be so easy. :eek:
    then.
    turn screw to adjust vibrator.
  6. CheaterCarl
    CheaterCarl
    That's what she said... Too Soon?
    Cheatercarl
  7. 29nash
    29nash
    from colorado
    Lube will always help!:D
  8. Thanks for all the input fellas. I have hooked it up to my 12v truck and it worked fine. Hope that was not a bad thing to do? I'm going to bead blast it tomorrow and see how it looks underneeth.
  9. 29nash
    29nash
    from colorado
    A 6v horn will work very well with 12v, louder and higher pitched. Long continuous operation might burn it out, but I have on Nash hot rod that has been working a couple of years now. It has a unique sound........
