History Can anybody tell me what is going on here?
Discussion in 'The Hokey Ass Message Board' started by Morrisman, Dec 28, 2012.
  1. Morrisman
    Morrisman
    from England
    Apologies if this has been posted, but I've not seen it anywhere.
    It looks like a small block Chevy to me, but get a load of those heads? There's one head on the floor to the left. Anybody know what motor it is?
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Looks like a dragster blowed up, go boom.
  3. TANNERGANG
    TANNERGANG
    from alabama
    1st HYBRID...........hehehehe.....i just had too
  4. Whatever it is, it looks like it is a reverse flow engine.
    I like it!!
    BTW, check out that offset quickchange rearend in the background
  5. Whats going well on is they ground a custom cam and are feeding the intake to the exhaust ports with two blowers. Could tell you for sure what engine that is.
    On second thought, it looks like the exhaust is exiting under the blowers. On the head you can see the intake and exhaust ports on the same ( outboard) side of the head
    So that's some weird stuff
  6. propwash
    propwash
    from Las Vegas
    Definitely waiting to hear an answer to that question - I mean, I can see what's going on, buta few things are confusing me - intake ports are now on side with exhaust ports?, custom-made valley cover with breathers. For sure it is an interesting exercise in full-tilt engine modification.
  7. scoop
    scoop
    Reverse the intake and the exhaust?
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    Really strange. Looks like somebody was seriously into experimenting. I don't think that is a sbc though, but could be wrong.
    Don
  9. toxic waste
    toxic waste
    from Iowa
    That looks like the Pontiac engine Mickey Thompsom was working on.
  10. Morrisman
    Morrisman
    from England
    That's just my point. When you look close you think WTF??? :confused:
  11. GOATROPER02
    GOATROPER02
    from OHIO
    I'll take a stab....Pontiac
  12. brigrat
    brigrat
    from Wa.St.
    Yep no SBC!
    Spacer/adapter between head and block?
  13. Mopar Jack
    Mopar Jack
    awwwwwwwwww.........ummmmmmmmmmmmaaa.......aaaaaaaaaaaaaaaaaa.....im still scratching my head...
  14. brigrat
    brigrat
    from Wa.St.
    Blowers probably running the same ratio BUT they swapped pulley sizes. Motor in mock up stage hence the "C" clamped motor mounts. Drivers side head blower combo looks higher than the pass. side. Idler pulleys not made by the same guy?
  15. toxic waste
    toxic waste
    from Iowa
    If you look at the head on the floor. You can see all the ports are on the outboard side.
  16. toxic waste
    toxic waste
    from Iowa
    One blower is higher so that the same belt length can be run. It will be different offset because blower drive snout is off to one side on the blower.
  17. need louvers ?
    need louvers ?
    Pretty sure you nailed it right there. About '61 or '62 Mickey had a dragmaster framed rail that musta had velcro engine mounts in it, 'cause every month he was featured in Hot Rod testing some other combo. This looks to be one of them.
  18. It looks like the idea is to put all the pressure from one blower into four cylinders instead of eight. Would be harder to try to do that with the ports in the normal position. And it does look like a Pontiac block with all cooling provisions removed or blocked off.
  19. ronzmtrwrx
    ronzmtrwrx
    Check out the burst panel/pop off plates between heads and blowers.
  20. brigrat
    brigrat
    from Wa.St.
    The tall breathers don't look like any M/T breather I have ever seen but maybe one off like the heads? If the heads had VC we would know the mystery.....................
  21. Wild Turkey
    Wild Turkey
    Where's the mag?
    Are the blowers counter rotating? The blower drives seem to be set up on opposite sides.
    What about the rollers (or whatever) just above the blower intakes.
    Looks to me like someone couldn't fit enough blower between the heads.
    But why didn't they just swap the intake/exhaust and run the exhaust straight up?
    Lots of work on that!
  22. Tnomoldw
    Tnomoldw
  23. rooman
    rooman
    Definitely not a small block Chevy. The block is totally wrong for that. It may be a Rambler motor as I think that they had that curved end on the valley on one of their blocks.
    The head that is on the ground to the right of the car shows what they did. The intake ports now come in from the outside between the exhaust ports. Not sure why you would want to go away from a cross flow configuration and hang the blowers that far out.
    Both blowers are the same height relative to the heads but due to the fact that the drive pulley is on the left side of the blower (when mounted the conventional way) the drive package is asymetric.
    Roo
    I guess that Tnomoldw got it right while I was typing.
  24. Squablow
    Squablow
    A lot of inline engines have the exhaust and intake on the same side of the head, I wonder if those heads weren't sourced off of some kind of inline 4 cylinder or a cut down straight 6 of some kind. Pretty wild engineering.
  25. Beau
    Beau
    :D
    That is amazing!
  26. HealeyRick
    HealeyRick
    from Mass.
  27. Don's Hot Rods
    Don's Hot Rods
    from florida
    You pretty much nailed that one, louvers, but look at the picture, he was actually using C Clamps. :D
    Don
  28. wallyracer449
    wallyracer449
    port dimensions aren't limited by push rod intrusion
  29. Pharouh
    Pharouh
    Almost looks like something Mickey Thompson would have built.
    Maybe it was to give the driver a better view of the road...:D
    I wanna know too.
  30. I see no spark plugs either. But with a single blower on each bank the final compression has to be ridiculous, it might fire just from that if you can spin it fast enough, like how a diesel works.
