Technical Can any one identify this carburetor?
Discussion in 'The Hokey Ass Message Board' started by Tickety Boo, Mar 24, 2020.
  1. Tickety Boo
    Tickety Boo
    from Wisconsin
    Been organizing the shelves, don't know what this fits. I know carb 3.jpg this is the place to ask
    Thank You
    Deuces likes this.
  2. TA DAD
    TA DAD
    from NC
    Motorcraft
    Tickety Boo and Deuces like this.
  3. Tickety Boo
    Tickety Boo
    from Wisconsin
    Thank You, any idea of the cfm or what engine they were on, like maybe a Y block?
  4. greybeard360
    greybeard360
    Late 60's thru the 70's up until TB injection took over.
  5. TA DAD
    TA DAD
    from NC
    I would look at Continentals , 70's even 80's had that carb. 428/460 engines. I am not a Ford expert by any means. Most I came across had 2bbl on them. Y blocks from what I know ( which is little ) had Autolite 4 bbl.
  6. Tickety Boo
    Tickety Boo
    from Wisconsin
  7. squirrel
    likely an Autolite 4300A, made from 67-74. Not much demand for them these days...but you might get a little for it on ebay.
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
  9. uncle buck
    uncle buck
    There’s a flat spot on the side of one of the mounting flange that has letters stamped in it. What are those letters?
    Sent from my iPhone using H.A.M.B. View attachment 4617798
    Deuces and Tickety Boo like this.
  10. Boneyard51
    Boneyard51
    Like said, this was Ford’s last four barrel carb, aimed at lower emissions and better fuel mileage. It seem to accomplish it somewhat and was a lot more complicated that it’s predecessor. My Dads 1974 F250 had one on it. It worked good new. With a 460, dogged off convertor and the highest gears in a 3/4 ton truck, I ever saw,it got 16mpg when new!
    Bones
    Deuces likes this.
  11. leon bee
    leon bee
    Got one of them on my 74 Mark 4 460.
    Deuces likes this.
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    Sorry Uncle Buck, could not find any number or flat for stamping any where on the base plate.
  13. town sedan
    town sedan
    Smog carb, good for a dusty garage shelf.
    -Dave
  14. uncle buck
    uncle buck
    Like this
    Deuces likes this.
  15. squirrel
    Probably had a tag on it at one time.
    Also note that this is the earlier version, before they made it into a spread bore design.
    Boneyard51 likes this.
  16. uncle buck
    uncle buck
    Looking at your picture in the first post of it upside down, it should be on th side of the lower left mounting hole. The tag on top looks to have the info broken off in your second picture
  17. Tickety Boo
    Tickety Boo
    from Wisconsin
    Yup, that area is blank on this one, the number must have been on the tag.
  18. town sedan
    town sedan
    May have been a service replacement part. I try to avoid buying carburetors without their original tag still intact.
    -Dave
  19. Boneyard51
    Boneyard51
    Good eye! I missed that! Actually saw the old pattern, forgot they made a spread bore later!
    Bones
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think the spread bore version was labeled 4300D.
  21. squirrel
    yes, and later the 4350
  22. dalesnyder
    dalesnyder
    I think AMC borrowed a similar carb from fomoco too.
  23. squirrel
    AMC never missed out on borrowing a bad design from someone else :)
    ottoman, slayer, Dick Stevens and 4 others like this.
  24. MAD MIKE
    MAD MIKE
    from 94577
    FWIW.
    All of the 4300 series carbs were spread bore.
    Trans Dapt 2199 adpater for the square bores on a 4300/4350 intake.
    https://www.hedman.com/product-detail/2199
    There are three different 4300s and a final 4350 found on EGR 460s of the late 70s.
    4300A 441 CFM
    • 1" primary venturi
    • Primary throttle bore: 1-7/16"
    • Secondary throttle bore: 1-9/16"
    4300A 600 CFM
    • 1.25" primary venturi
    • Primary throttle bore: 1-9/16"
    • Secondary throttle bore: 1-11/16"
    4300D/4350 715 CFM
    • Secondary throttle bore: 2"
    town sedan likes this.
  25. squirrel
    No...
    All of them had different size primary and secondary bore sizes, but only the 4350 had the secondary bores spaced apart. That's what the "spread" means.
    Lloyd's paint & glass likes this.
  26. Yes, I worked for AMC back in those years. Both Jeep and AMC cars used that carb.They actually worked pretty well ... when they were new.
  27. I’m not sure who they borrowed the 258 from but that is a very reliable engine. Had a few jeeps with that six that I abused regularly without a hitch.
    The AMC rear diff. is another story altogether.
  28. AMC 258 was their own engine. A very solid inline 6.
    squirrel and wraymen like this.
