Technical Can a Malfunctioning Tach cause Ignition issues?
Discussion in 'The Hokey Ass Message Board' started by Nailhead Jason, Sep 23, 2019.
  1. So I have just got my 39 running. I am using a stock GM points Distributor in the 283 small block. New Points NOS Mallory condenser from the 70's so its good quality. Timing is at 12 degrees advanced. Here is the issue. I can go out and crank it up to start and it will fire right off and idle perfect, Shut it off, and you might be cranking it for 20 min before it will fire again, sometimes poping out the carb, sometimes poping out the exhaust. Turn it off, then back on hit the button and it will fire right up. make no sense at all.
    I pulled the distributor and set it all back up again, put it back in and it fired right up. Having only about 1 mile of drive time on it, I took it for spin around the neighborhood. It was running but not as smooth as it should have been, and somewhat lacking in power. it was then that I noticed the Tach was acting very weird. I could rev it up, but it would never go over about 2500 RPM, and was very slow moving. So I have a Feeling this tach is not working properly. It just didn't seem to line up to what the engine was doing. Got back to the house, pulled in the drive way, shut it off, went to fire it up, and same thing......no start, pop out the carb. shut it off came back 10 min later fired right up.
    Now my question is this... The tach is a neat old AC Delco Tach, that is def old, was NOS in the box when I got it, It was marked for an 8 CYL on the rear case, and required no box to drive it. its just hooked straight up to the coil negative terminal. Is there a possibility, that this tach, is causing me issues? can it ground out the negative side of the coil and make it do weird stuff in the process? I plan on disconnecting the signal wire from the coil this evening and test it. Im at work now and just sorting of thinking out loud about it. Any thoughts, experience or input appreciated.
  2. Oh and all the wiring is new and tests good, i'm not losing Voltage to the coil when it wont fire, I am getting spark, but it looks weak and is very sporadic.
  3. das858
    das858
    In the late '70's when i was a mechanic at a chevy dealer one of the first steps we would do when we had a no start , no ignition problem was to disconnect the tach . Give it a try !
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    Might try a different condenser. Sounds like the one in it now isn't doing it's job.
    Nailhead Jason likes this.
  5. that was my first thought as well, I have swapped out 4 different condensers with no change.
  6. I've only had one car in my entire life with a tachometer and it was factory equipment on a 1963 1/2 Falcon Sprint, I was doing some repairs on the dash and I removed the tach, when I had completed my work the car would not crank.
    So from my limited experience I would say it's possible, I'll wager Jim Forbes will know for certain. HRP
    bighemifan and Nailhead Jason like this.
  7. Yes, a bad tach could cause the ignition to give troubles. It's also possible the tach is misbehaving because of an ignition problem. I once had a tach that was very erratic because of a worn out breaker plate. The engine seemed to run fine but the tach sure didn't like what was going on.
    Boneyard51, j-jock and Nailhead Jason like this.
  8. If the Tach reading had not been so off and slow responding, I would never have thought that it could have anything to do with it.
  9. Boneyard51
    Boneyard51
    The factory Ford tach of that era had the ignition running through them! Most tachs just have a signal wire going from the coil into the tach. But both kind can cause engine runnablely problems.
    Bones
  10. Black_Sheep
    Black_Sheep
    I would disconnect the tach wire from the coil and see what happens...
    bob b. and firstinsteele like this.
  11. Disconnected the tach wire from the coil tonight with no change. Couldn't get it to fire at all. The points dont seem to be holding adjustment. Set the gap and got it to start. A friend of mine has some NOS gm points from the 60s so I'm gonna pick those up and try swapping those.
    lothiandon1940 likes this.
  12. Joe H
    Joe H
    I just rebuilt a GM distributor for a '71 Pontiac TA. I used new store bought points and condenser. It would not make a decent spark above 3500 rpm on my distributor machine. Found a NOS set of Delco's at a swap meet and put them in place. Not only could you hear the difference due to the heavier spring, the spark sat right on the money from idle right to 6500 rpm with no problem. In a last ditch effort if the NOS don't pan out, double up the spring and see if that helps.
    I had a '62 Pontiac tach in a '66 Mustag 289, used what I had, that caused a no start issue. Unhooked the tach, fired up and drove home. Tach went back up on the shelf.
    lothiandon1940 and Boneyard51 like this.
  13. bighemifan
    bighemifan
    wicarnut and Elcohaulic like this.
  14. wicarnut
    wicarnut
    Be curious to read solution when problem is solved, back in 60's, first car I put together at 16, swapped in engine, ran good, burnt points quickly, sharp man at parts store asked me about the ballast resistor, he showed me one, told me to look see, I did not have one, installed it, problem solved. do you have one wired in ?
  15. I have a brand new ballast put in. It really makes no sense. Hoping the NOS points will help
    wicarnut likes this.
  16. wicarnut
    wicarnut
    If different points/ condenser doesn't help, check continuity on all your primary ignition system wires pulling wiggling them to be sure not broken under insulation, had that happen to me years ago, car would shut off, cool off/start and run till warm. weird deal, took a while. Your Ignition switch new/good, all the normal stuff check, cap, rotor, plug wires, coil. All your grounds.
    Boneyard51 likes this.
  17. Truck64
    Truck64
    from Ioway
    If the distributor itself is all clapped out they will never read the same twice. Worn bushing/shaft etc.
  18. I agree completely, but this one is tight, and right. It was in a 62 Chevy truck that was perfectly a preserved time capsule, and only had 19,000 miles on it. I Picked it up when I got the entire drivetrain out of it, when the new owner performed the blasphemy of an LS swap.
    Truck64 and Boneyard51 like this.
  19. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Is the distributer getting a good ground to the engine?
    Is the hold down tight and making good contact on the distributer?
    Just a couple of thoughts.
    KK
  20. Truck64
    Truck64
    from Ioway
    Wow, I suppose you already told the tale, but where did you find that?
  21. RMONTY
    RMONTY
    You might try doing what I call putting it on life support. Run a basic ignition circuit from the battery with no switches or anything but a single wire from the battery and test from there. No tach, no switch, no nothing, and see how she runs.
    wicarnut and firstinsteele like this.
  22. Has anyone mentioned just disconnecting the tach wire from the coil and road testing it?......
    427 sleeper likes this.
  23. Truck64
    Truck64
    from Ioway
    That's crazy talk
  24. bighemifan
    bighemifan
    Perhaps try a different coil. Sometimes they provide sufficient build up when cold, but when they heat up, they can break down too soon and weakens the spark. Although you still get spark, it may not be sufficient. Had that happen on a 63 390 T Bird. Just quit in Winnemucca Nevada, which in those days was 40 miles past nowhere. Made it a beat up gas station & this ole greasy mechanic pulled out this little homemade spark distance tester attached to a board. Showed me where it was working, but weak by turning a screw that increased the gap. He went out behind the station & come back with an old coil off of a wreck. Screwed it on & eureka. Charged me 2 bucks for the coil & it was still on the car when I sold it years later. Just an easy thing to try.
    427 sleeper, Gerrys and wicarnut like this.
  25. sunbeam
    sunbeam
    I had a 64 impala with a warmed up 327 with a 6000rpm factory tach and replaced it with a new stewart warner tach and it would break up at about 5000 rpm. Traded it for a factory 7000 rpm 409 tack and every thing was fine.
  26. hotrodtodd1960
    hotrodtodd1960
    When I built my Willys pick up it had a miss when I got on it , started changing everything one at a time carb , distributor, alternator, key switch, finally found the problem - cheap ass Chinese moon Tach wished I would of changed it first
  27. sunbeam
    sunbeam
    How about you remove the tach wire from the distributor side of the coil and see if the problem goes away
    427 sleeper and TrailerTrashToo like this.
  28. Post #11, he tried this and it had no change.
    Is it possible your ignition switch is not up to the task? You said that after cranking with no start, turning key off and on and then pushing the starter button lights it off. Do you have the bypass portion of the ignition/solenoid circuit wired so you get the full 12v to ignition in start?
  29. tubman
    tubman
    When we were developing our 6 to 12 volt tach driver, we fried one of the components on a test unit. It caused the engine to just quit. I unhooked the tach and the car stared right up. On a post-mortem, my partner found the failed components and said "Yeah, that would do it".
  30. sunbeam
    sunbeam
    People are saying you cant find good points there is a guy on ebay selling new old stock GM UNI points for $10 a set.
    wicarnut and wraymen like this.
