I have the opportunity to purchase a solid 54' Chevy pick up. I really prefer the 47-53 but this one is really clean. Can a 2 piece windshield be put into a 54'. Is the dash sheet metal the same just different gauges? The front fenders with the truck look like the 47-53, the corners of the grill opening are square not rounded. Did they make a 53 1/2 by chance. Any help would be appreciated. Thanks, Rob
The upper cowl, roof leading edge, windshield posts and dash are totally different. If you want to change from the one piece curved glass you will need to replace the entire windshield area and the dash. Removing the dash from one of these trucks involves drilling out a couple hundred spot welds. Interestingly I changed my two piece windshield to a one piece curved one. I am crazy enough to do it but don't recommend it. I made a bunch of other changes while I was at it. The Rod and Custom dream truck changed from a two piece windshield to a one piece by installing a '54 cab. If you really want the two piece windshield finding a different cab may be the way to go.
I much prefer the earlier trucks too, though admit the '54 & '55.1's are growing on me. Depends how exceptional the one you found is. Don't settle is my advice. I wanted a '55.2 big window with a 5 lug conversion and a V8 and I waited (& waited, & waited, & waited) until I found it. Glad I did.
Just to add to the confusion, my '55 1st series came from the factory with 2 piece windshield, along with RHD. I wouldn't change my grille for anything.
There's nothing like a split-window AD and if that's what you have your heart set on, pass on the 54. There's plenty of 47-53 ADs for sale, hell, you can even build a complete new one, with all the parts available. And the majority of reproduction parts are for the 47-53 ADs.
Thanks a lot guys, appreciate the help. Looks like I'll have to leave it where it sits. I really have my heart set on the 47-53 body style. The truck is totally disassembled, the fenders have me puzzled a bit as they sure look like the 47 - 53's. The guy has parts spread all over so it's hard to see what's there. He actually two 54's. One is complete and in not as good a shape as the one that's disassembled. That one for sure is a 54' because it has the grill and everything in it.
Lose the big "tooth" in the grille, maybe add a Cadillac center, 54 passenger car front bumper, dropped axle... Just sayin...
I don't care for the '54 grill, funny I don't care for the '54 ford grill either. LOL. You can bolt the earlier sheet metal to the cab, and that will clean up the front, or you can just clean up the front and make the earlier grill fit. There isn't enough difference in the dash that you could not modify the dash to look the same as the old dash or you could just fill the dash and build it the way that you like.
I have a '55 first series with a '47-'53 nose on it. I actually like the one piece windshield with the earlier sheet metal better. Andy
