Is 4 to 8 th the allowable end play for a 52 ford flathead v8, I have more near 22 th what is the repair? Sent from my iPhone using The H.A.M.B. mobile app
Google Delta Camshaft in (N.West) They can tell you the easiest route, as they do a lot of flathead work. Friendly over the phone advice, fast service & mailing. Believe the problem is wear between cam nose and timing plate.
Read all of this thread, especially posting #12 for solution to end play problem. https://www.jalopyjournal.com/forum/threads/flathead-v8-timing-gears.337858/
Thank you 19fordy, I’m going to machine the timing cover to except a brass thrust bushing. Wayne Sent from my iPhone using The H.A.M.B. mobile app
