Cams for a 325 Poly Hemi????
Discussion in 'The Hokey Ass Message Board' started by nutwagonfromhell, May 20, 2011.
  1. nutwagonfromhell
    nutwagonfromhell
    from missouri
    I`m looking for a performance camshaft for a 1957 dodge 325 poly engine. Anybody know where I can find one?
  2. RichFox
    RichFox
    Google Elgin Cams. Or Dema Elgin.
  3. Pete1
    Pete1
    from Wa.
    I can do one for you if you have a core.
    PM me.
    Pete
  4. George
    George
    Chris Nielsen also
  5. Bert Kollar
    Bert Kollar
    Oregon cams can make anything you want
  6. HeyyCharger
    HeyyCharger
    Pete's the man you want to see about cams.....
    HC.
  7. Comp Cams now has "Thumper" grinds for many of the vintage engines, call and ask fro Chris Padgeat.
  8. 73RR
    73RR
    There are NO new cores. So, using a regrind is your only option. There are many small shops that can cut your stock shaft as well as most of the 'big' guys.
    Your job is simple, find the profile that you like and have that company do the work. Troll through the catalogues on line and see what else is used in a 325 inch engine.
    However, be cautious about using anything other than a Mopar grind since they are designed for the large diameter lifters. Brand 'x' profiles will certainly work, but they will not be optimal. If you just want to freshen up the stick and do some cruising then just about anything will work.
    You will also need adjustable pushrods or you can convert your rockers to adjustable.
    We are having some computer problems related to our CamDoctor so I won't offer to do the cam right now but we can certainly make pushrods or convert your rockers.
    Good luck.
