Technical cam lobes problem
Discussion in 'The Hokey Ass Message Board' started by olscrounger, Jun 3, 2020.
  1. olscrounger
    olscrounger
    Helping with a cam install on a Chevy small block. Fresh machine work etc. New cam bearings etc etc. Tried to put cam in and no go. Then tied a stock cam--no problem. Friend took back to machine shop.
    He tried the same--stock cam ok, after market NG. Lobes higher than bearing surface by .005 to .010 larger!! Never seen this before--returned cam and waiting for another. Anyone seen this before?
  2. squirrel
    that's a new one on me! Congrats.
    bobss396 and Deuced Up! like this.
  3. theboss20
    theboss20
    Sounds like an old block...maybe even a 265 sbc...
    Sent from my iPad using Tapatalk
    bobss396 likes this.
  4. hummm Chinese cam?????
  5. olscrounger
    olscrounger
    Yep Jim me too-I checked it too. Friends Uncle is doing most of assembly and he could not believe it either. He is an engine guru in his late 70's and has built Offys etc etc and still builds high end sprint car motors as well. Has done this for 50 +years. Summit is sending a new cam. It is a 70 350 that has been bored, decked, line honed etc etc by a high end machine shop.All was good til cam install.
    theboss20 likes this.
  6. Ericnova72
    Ericnova72
    from Michigan
    What does that have to do with anything....thyy all have the exact same size cam bearing bores in them. Every stock SBC block ever made has the same size cam bearing bores.
    The only difference in the very early 265 is that there is no oil annulus groove behind the bearings so it requires a cam with a groove cut in the rear bearing journal on the cam for proper oiling.
    Sounds like the cam grinder screwed up, lobe should never be higher than bearing journal diameter.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Monday morning on the cam grinding machine.
  8. olscrounger
    olscrounger
    ^^^ No kidding!! Never seen such a thing.
    lothiandon1940 likes this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Was it a custom grind?
  10. olscrounger
    olscrounger
    No custom grind Crane 266/440 have installed many--installed two last year in 327's
    mild cam--used to be the same specs from Cam Dynamics in the 80's
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
  12. Sounds more like 266/880 :eek:
  13. partssaloon
    partssaloon
    I'll be interested to hear the outcome of this one!
  14. More than enough lift. Sounds like a bad set-up on the cam grinder. I spent 15 years with an aftermarket cam mfg who supplied OEM and the HP marketplace. Can't remember ever running across that particular problem.
    lothiandon1940 and Johnny Gee like this.
  15. I have put together quite a lot of SBCs.......never saw lobes that were bigger than the cam bearings......
  16. Add me to the “never seen that before” group
  17. olscrounger
    olscrounger
    me either but it was that way. Talked to a custom cam grinder a bit ago and he said it is very rare but does happen. He has seen it before.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    CNC - Can't Knock-off Copy's
  19. I wonder how the cam could be installed with lobes outside the journal diameter.......some kind of voodoo? Two-piece bearings? Sounds like a data input mistake on the machine........right cam, wrong lobe profiles.....
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It's a set up error or a bad joke by a pissed off employ.
  21. LAROKE
    LAROKE
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ They were Big Lobes!
    LAROKE likes this.
  23. Probably a dodge cam
    ClayMart and Redrodguy like this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Of a different era.
  25. gene-koning
    gene-koning
    We bought a cam once where the bearing journals were larger diameter then the bearing inside diameter. Sent it back and they replaced the cam with one of the same part number, the second cam was good.
    Stuff happens and sometimes slips by the inspection point. Happens with everything from time to time. Get the replacement and move on. Gene
    dirty old man and olscrounger like this.
  26. olscrounger
    olscrounger
    The replacement is already enroute.
  27. Deuced Up!
    Deuced Up!
  28. alchemy
    alchemy
    I've read about a vintage engine that had a notch in the journal for a tall lobe to fit through. Can't remember where I saw it or the engine type though. Was probably really old and just a splasher system that didn't have pressured oil to a bearing. Some old engines ran the cam directly on the iron bore in the block.
  29. Blues4U
    Blues4U
    from So Cal
    Cummins B series engines (the engines in OT Dodge pickups as well as a million other applications) have no cam bearings, the cam rides directly in the bore of the iron block. Bearing inserts are available for rebuilding engines, but they do not come with them originally (same thing with cylinder liners).
    Truckdoctor Andy likes this.
  30. Not to mention virtually every overhead cam application runs without bearing inserts
    Blues4U likes this.
