Hot Rods calipers
Discussion in 'The Hokey Ass Message Board' started by sdluck, May 2, 2019.
  1. sdluck
    sdluck
    On the front of my model A dropped axle, are disc brake calipers they have casting number E64328816 on them,they didn't show up on google and my local parts supplier does't know them either.
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Pictures would prove most helpful!
    KK
  3. sdluck
    sdluck
  4. sdluck
    sdluck
    I should know better,thanks.
  5. how about a picture of the entire caliper.
    Mr48chev and Beanscoot like this.
  6. judging by what I see in the picture there, they almost look like old Hurst/Airheart type discs
  7. sdluck
    sdluck
    The cars is not here I will get a better picture, thank you
  8. sdluck
    sdluck
  9. sdluck
    sdluck
  10. sdluck
    sdluck
    Trying to ID these
  11. The non-ventilated rotors leads me to believe those are sourced off something older. You haven't posted a full pic, but those look a lot like older Volvo (late '60s/early '70s?), those were a semi-popular early disc swap before discs became common on American cars.
    If that's what they are, you may have problems finding replacement parts.
  12. Weedburner 40
    Weedburner 40
    They do appear to be Volvo's, early Jaguar's used those calipers also. Check with Moss Motors in San Luis Obispo, Ca. for parts.
  13. DDDenny
    SD
    I haven't seen them for years so I can't say positively that they are Volvo but many years ago a friend of mine with a chassis shop used Volvo 122s disc brake components for some of his conversion kits and I know other guys used them.
    Like others have said, not a lot of replacements to be found easily nowadays.
  14. Mr48chev
  15. Fordors
    Fordors
    Your spindles probably have a 1/4” or so spacer to move the inside bearing toward the outside. The inner bearing will be the early Ford and the outer Volvo. Grease seals are National 224046
    Replacement parts? Really what will you need? A caliper might be hard to locate but rebuild kits are available
    Just about all aftermarket kits moved on to vented rotors, but solid worked for Volvo, Jag and a host of others for years, I’d keep ‘em.
  16. X-cpe
    X-cpe
    I went out to the garage and looked at a set of 122S rotors and calipers on the shelf. (I have an innate ability to keep stuff until it is worthless.) Some of the cast numbers weren't absolutely clear. For the number in post 3 mine have (E64326816).(The first 6 looked more 6 than 8.) For pictures 1 & 2 in post 8, my number is ('some unidentifiable lump'4325793). In picture 3 of post 8 I have (DA1?698).(The 6 was a best guess read.)
  17. sdluck
    sdluck
  18. sdluck
    sdluck
    I will try an get clearer pictures
