Cadillac Flathead - Valley Plates Casting Project.
Discussion in 'The Hokey Ass Message Board' started by fiftyv8, Jun 18, 2009.
  1. fiftyv8
    fiftyv8
    from CO & WA
    You may recall I did a Thread sometime back covering my 1st attempt at making a pattern and casting up a timing cover for 346 Cadillac flathead engine as there is not much out there accessory wise for these monsters. http://www.jalopyjournal.com/forum/showthread.php?t=311796
    Well I decided I wanted some finned aluminum valley plates to give my project a bit more of the traditional hot rod look.
    So this is what I ended up with.
    Just to let the flathead Cadillac engines guys know if they are searching for parts or info there is a new site http://www.flatcaddy.com/
    which may be worth a look.
    My next casting project will be a pair of finned aluminum engine mount covers, these covers will stock as well as hot rods running the original mounts. Any body who has one of these engies will know how ugly the engine mounts look.
  2. 38FLATTIE
    38FLATTIE
    from Colorado
    Wow Russ!
    They look great! Are you doing covers for both sides of the mount, or a 'box' type that will cover the whole thing?
  3. fiftyv8
    fiftyv8
    from CO & WA
    My plan is to cover the metal arm off the side of the engine and most of the rubber cushion if possible but the aim is to fit stock and most hot rods running stock style mounts. They got to look better than the factory finish.
  4. 38FLATTIE
    38FLATTIE
    from Colorado
    That will really help the 'look'!
    I can't wait to see pics!
  5. emiliedk
    emiliedk
    from denmark
    looks good Russ!...
    -palle
  6. resqd37Zep
    resqd37Zep
    from Nor Cal
  7. povertyflats
    povertyflats
    from Missouri
    Good job Russ. I was wondering what you have been up to lately. I should have known it would be something cool like this.
  8. 38FLATTIE
    38FLATTIE
    from Colorado
    Russ,
    while you are at it...
    How about a dipstick cover, an oil pan, oh never mind! That's my Xmas wish list!:D
  9. 38FLATTIE
    38FLATTIE
    from Colorado
    Russ,
    I received the valley plates. WOW! They look great, and fit perfect.
    Super nice job!
  10. flatout258
    flatout258
    I think it would be a good idea to install a p.c.v. in the valley cover. All you need is a vacuum source, and the engine runs cleaner because of crankcase vacuum instead of pressure.
    I also built a cover for my mounts using Caddy emblems on the plate.
  11. fiftyv8
    fiftyv8
    from CO & WA
    Yes, the plates have been cast with the view to using a PCV if required.
    The center circle area has enough depth to cope with drilling or machining a PCV point of choice without disturbing the fins.
    Also, on the underside I have provided a substantial lip all the way around so a sludge tray could be attached (on one or both) and a suitable filling installed to help prevent oil fumes wofting thru.
  12. fiftyv8
    fiftyv8
    from CO & WA
  13. fiftyv8
    fiftyv8
    from CO & WA
  14. 38FLATTIE
    38FLATTIE
    from Colorado
    Russ, do you still have the valley plates, or did they sell?
    I wish I had seen this sooner!
