I’m about to run a rebuilt motor built from parts and have a problem. Could someone please give me some measurements of a 57 Cad dip stick and tube. I have a few Cad motors( thinking I could use one off the others) but didn’t realise the dip sticks were different,even on either side depending on the year. The one I’ve built is a 57 as said and the stick is on the passengers side(in the US). What I need is the length of the stick and measurements from the stop washer/cover down to the Low/Full lines and the length of the tube itself from the block. Hoping someone could get me a picture of the stick with a tape along side it . Thanks in advance , Chris
I don't know if this will help you, a fellow I know broke his tube off and I suggested using whatever tube would fit. Drain all oil from the block and refill with the required amount. See where the oil level registers on the new stick and make a mark. Just a thought.
Thanks for the suggestion, if worst comes to it I’ll have to go down that path but hopefully someone can help me with the correct measurements. Thanks again though .
Yeah that’s why I want to try and get this right, still surprised there are so many differences in the same style blocks.
According to all the manuals I have my 61 390 holds 4 quarts . I thought this was odd but sure as s#&% after putting in 4 quarts and pre lubing the engine the factory drivers side dipstick read full. Chris I know this doesn't Answer your 365 question. But Maybe look at the factory specs for a 57 and fill and prelube the engine and mark your own dipstick?
Hey Lumpy, Yeah, I have the same info, yours is 4 qrts , mine is 5 qrts. I had a win tonight, I put 5 in and primed the motor with a battery drill and it bled up beautifully. Buttoned up the rocker covers and valley cover, had to lightly file the distributor intermediate shaft flats to engage it in the oil pump fully without forcing it and fit the distributor. Once I can get the dipstick info and get it sorted she’ll be ready to fire. I could do as you suggest but a little patience and it will be right and I won’t die wondering. Cheers
Here is the answer to your question. '57 Cadillac. Tube, from block surface to top of tube - 8.750" Stick, from flange to end - 22" even. Flange (stop) to full - 17.750" Flange (stop) to add - 18.625" All numbers + or - , .0625 Enjoy.
Slow to the game here, but here are some pictures. The tube itself is 10" from opening to where it enters the block.
Not sure why the last file did that. I resized it, here it is again. Hope it helps, if not, I have more pictures. I pulled this engine from a 1957 Series 62 that was very much original. It's not anymore. The rest is off topic though.
Hey man, I usually get paid for this, but there's a cad Lincoln salvage in OK, they should have the dipstick & tube ya want..aabars.....
