Projects buying an ole can a beans:my 29 ford
Discussion in 'Traditional Hot Rods' started by Austin kays, Jan 13, 2018.
  1. Austin kays
    Austin kays
    Well I’ve got a bit of a story. I found some decent 21 stud aluminum heads online I think they could probably use a re surface but usable as is so I got a hold of the local fella in my small town he’s got a small machine shop and said he’ll see what we can do with them. Turns out he’s a hotrod guy too check out this neat neat head he has. Hotrodding introduces you to the neatest folks IMG_8230.JPG IMG_8227.JPG
    dana barlow, Sancho, Tim and 4 others like this.
  2. Cool build! Love your "shop" too. Very traditional.
    Austin kays likes this.
  3. Austin kays
    Austin kays
    Appreciate that @Rocky only the finest dirt floors over here haha.
    Stogy, Outback and brEad like this.
  4. Austin kays
    Austin kays
    Sancho, Stogy and brEad like this.
  5. Austin kays
    Austin kays
    In the heap of parts I bought I got a new intake manifold gasket and a couple 94 gaskets for the carbs. Does anyone know what type of head gasket would be best to use on this I’ve read a few different things but curious to what you guys do.( that still like these old turds) (flatheads that is )
    Sancho, Tim and Stogy like this.
  6. Austin kays
    Austin kays
    IMG_8370.JPG Well there’s half the motor on my table haha ;) glad to have it all here now. Gonna need a few odds and ends but over all I’m happy with my new aluminum treasures. Gonna start polishing here soon. If anyone wants to chime in with some beginners dos and donts I’m all ears.
  7. saltflats
    saltflats
    from Missouri
    Don't the head gaskets need to fit the quench and piston to head clearance ?
  8. Austin kays
    Austin kays
  9. Austin kays
    Austin kays
    I was talking about polishing the exterior just a heads up ;) haha get it that’s corny
    brEad likes this.
  10. Budget36
    Budget36
    I had a small aircleaner like you showed above on my flathead, single carb, dang thing fely like I was always into the throttle. After doing something, don't recall what, I drove off w/o the aircleaner on it. It was like driving a new truck. I modded up a normal size air cleaner for it, ran so much better. I suspect the little one restricted flow, but look into it before spending money on them.
  11. Austin kays
    Austin kays
    Will do I really liked just the edmunds “bird cage” it says you can fit a K&N filter jn there. I imagine there’s a few that will fit. Thanks for the heads up anyhow! Those things aren’t on the cheaper side by any means.
  12. Budget36
    Budget36
    Been some time, but the stock-ish 221's and 239's I had, wasn't anything to think about quench, just valve to head contact.
  13. Austin kays
    Austin kays
    This motor originally came out of a passenger car(which came with aluminum heads in 34’) and had its aluminum heads removed because of corrosion and iron ones fitted to it when it was over hauled by consolidated engine rebuilders back in the 50s or that’s what the tag says anyway. So I don’t think I should run into any trouble
    Stogy likes this.
  14. saltflats
    saltflats
    from Missouri
    Then set it as close as in limits. The better the pop the better the fun.
    Stogy and Austin kays like this.
  15. Austin kays
    Austin kays
    Good call. I forgot I put something up top about head gaskets. Haha Thanks for the reply! I’ll get it to squeeze as much as I can. I’m sure this old flathead could use all the help it could get
    Stogy and saltflats like this.
  16. Austin kays
    Austin kays
    IMG_8386.JPG IMG_8388.JPG IMG_8385.JPG IMG_8387.JPG well popped the heads off the Flatty today gotta say I’m pretty happy took about 20 mins to do one head. And looked really clean inside I don’t imagine there’s many miles on it after the rebuild was done years ago. I may have lucked out.
  17. Tim
    Tim
    from KCMO
    Looking good. I’m excited to see this thing cackle once more. Been to long!
    maybe we can park our A’s next to each other at pete and Jakes next spring
    Austin kays and Outback like this.
  18. Austin kays
    Austin kays
    Hey that would be a sight! @Tim I’m definitely ready to have it running
    Stogy and Tim like this.
  19. Tim
    Tim
    from KCMO
    You get yours running and I’ll get mine so it’s got something other than clamps and gravity holding it together lmao
    Stogy likes this.
  20. Austin kays
    Austin kays
    Yeah I think mine has all the bolts....
  21. Tim
    Tim
    from KCMO
    Or it’s just welded lol
  22. Austin kays
    Austin kays
    Tim likes this.
    Man, that is cool as hell.
  24. Jose Betancourt
    Jose Betancourt
    from San Jose
    Man looks like you are having a great time with your build! I'm having fun following along.
  25. Austin kays
    Austin kays
    Hey thanks! I got a little distracted with my 49 Chevy here recently but should have more progress next weekend :) IMG_8935.JPG there’s my newest distraction
  26. This banger head for sale??
  27. Austin kays
    Austin kays
    No I’m sorry it’s not.
  28. Austin kays
    Austin kays
    738EFF93-7B60-4224-85CE-5C328DCF9714.jpg Put all the junk back on the engine. Didn’t want any critters calling it home
    Stogy, patmanta, simplestone and 6 others like this.
  29. Austin kays
    Austin kays
    IMG_9523.JPG IMG_0515.JPG well found an old school bus seat for the rear and if I put just a little tilt to it it’s real comfy. However it is a little tight to sit in the front( pic for reference)
    Stogy, brEad and Tim like this.
  30. Tim
    Tim
    from KCMO
    Think you might need to drill That visor haha. Looking good bubba
    Stogy, brEad and Austin kays like this.
