Burning up coils ????
Discussion in 'The Hokey Ass Message Board' started by frankieC, Aug 7, 2013.
  1. frankieC
    frankieC
    Need help guys !!!
    I keep burning up coils 351w with axcel elct. distributor just replaced my 4th' coil inabout 5 years what could be causing it
    Any HELP PLEAS
    Frankie C
    38sled
  2. Jalopy Joker
    Jalopy Joker
    post pics of engine. has been threads on here about the importance of how to position one.
  3. frankieC
    frankieC
    Its mounted on the inner fender well passenger side ????
  4. mechanic58
    mechanic58
    Ever check the voltage at the + connection on your coil when your engine is running? Might be a good starting point.
    If its too high - that could be your problem.
  5. Fighter-of-Wars
    Fighter-of-Wars
    You prolly need a resistor before the coil
  6. frankieC
    frankieC
    Thanks guys anyone else (Bubba) ????
  7. hoop98
    hoop98
    from Texas
    What coil are you running?
  8. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    If it's upside down the electrons fall out ;)
    Though I guess there are SOME coils that are a bit picky about positioning.
  9. GassersGarage
    GassersGarage
    I know the old Accel Super Coil required a ballast resistor before the coil. It's been decades since I've used one.
  10. Mr48chev
    No resistor or resistance in the power feed to the coil to cut the voltage when operating sure sounds like it may be the cause.
    If it is a Super Coil the Jegs Add http://www.jegs.com/p/Accel/Accel-Super-Coil-Ignition-Coil/1732359/10002/-1 Says that it should come with a .85 ohm ballast resistor in the box meaning that they expect you to use the ballast resistor in the power feed to the coil.
  11. hoop98
    hoop98
    from Texas
    But the earth is positive so it should repel them (the electrons).
    Back to reality, oil filled coils need to be mounted vertically, TU (Terminals Up).
    Premature coil failure is related to heat. Excessive primary current can be reduced by ballast resistance. Since the coil is making it a year or so a small ballast resistor like the .85 should make it live a long time.
    High load due to secondary resistance or plug gap will stress the coil also.
  12. frankieC
    frankieC
    Thanks much all!!!!!
  13. hoop98
    hoop98
    from Texas
    MSD 8214
    .8 OHM
  14. Ross6860
    Ross6860
    What the others said. Mount upright, use a ballast resistor when running.
    Hint - Install a switch to bypass the ballast resistor while starting. Puts full battery voltage to the coil while cranking, which can fall off quite a bit due to the starter draw.
    You can install a relay to handle this automatically, or be cheap like me and install a three-position (SPDT) maintained switch under the dash. Run-Forward, Start-Back, Off-Middle. Doubles as a kill switch, too. About $4 plus wire.
