Technical Burning tires off rims
Discussion in 'The Hokey Ass Message Board' started by MrEarl, Apr 15, 2015.
  1. MrEarl
    MrEarl
    Looking at buying a set of 50's Buick rims from someone who says salvage yard may have burned the tires off. Question is, if so, would this hurt the structural integrity of the rim. Don't have pictures yet or else would share them. Thoughts?
  2. harpo1313
    harpo1313
    from wareham,ma
    I would pass.
  3. indyjps
    indyjps
    Tire fires are very hot. Assume the rims are bent badly, figure a way to bolt them to an axle and spin them to check runout before buying
  4. Probably would effect them,if it were me I would pass. HRP
    lothiandon1940 likes this.
  5. Even if they look OK, that kind of heat might actually change the molecular structure of the metal making it more brittle than normal and prone to cracking.
    HOTRODPRIMER and olcurmdgeon like this.
  6. R Pope
    R Pope
    Tire burning heat will soften the metal. They are leverite. (Leverite where you found 'er!)
    HOTRODPRIMER likes this.
  7. MrEarl
    MrEarl
    yea, my thoughts too, but the guy says it is standard practice to burn them off. Maybe for salvage metal but for usable rims??? I don't know>>>
  8. ................I'm no chemist but, I think you're right in that while they are hot they are softer but what happens when they cool down.
  9. Yeah,it is a common practice with salvage yard but it's also a easy way of removing the tires before the metal is scrapped. HRP
  10. theHIGHLANDER
    theHIGHLANDER
    They're most likely annealed now (softer than O.E.) so they'd never last in Motown. We have pot holes so big homeless folks can live in em.
    lothiandon1940 and Texas Webb like this.
  11. traffic61
    traffic61
    from Owasso, OK
    Might be usable to build a grinder stand, but even that might be questionable. I'd keep on looking.
  12. Mr48chev
    I'd agree, pass on those as they are only good for scrap. Back when I was a kid and long before that the city dump was in a canyon up in the hills about five miles from my house and the guys at the dump burned out cars that people had left there to scrap them. the wheels on them were pretty rough after they had had the tires burned off them.
  13. banjorear
    banjorear
    That sounds like an insane way to get the tires off. It would seem like it would be quicker and cleaner to just use a breaker bar or machine to do it.
    Tire fires cause some of the blackest, thickest smoke I've scene. Plus, it got to take longer for it to burn then it would be to do it right. Sounds lazy.
  14. Lots of weird crap goes on in the 'yard. I went into one to get a heater core for a Falcon... no problem. The yard guy took it out of the car with a fireman's axe...
  15. Had a pair once. Bent when mounting tire. Good for a roller
  16. MrEarl
    MrEarl
    OK, sounds pretty unanimous, me thinks I will pass. They were a screaming good deal is the only reason I inquired about them in the first place but after hearing they were subjected to no telling what degree of heat had second thoughts. THANKS guys for you input. Always impressed with how much experience and know how is on this site. And how many respond and quickly. Thanks again!!!!
  17. Yep scrap yard owners are a different sort of people. I went to the yard one time for a motor mount and while I was there they were busy torching the front end off of a '57 Chevy for the front suspension. they loaded it up frame stubs and all in the back of a fellas truck. Of course they did cut the core support and what was left of the rest of the stuff off first. :eek:
  18. 57JoeFoMoPar
    57JoeFoMoPar
  19. Jalopy Joker
    Jalopy Joker
    burns me up when good parts are wasted
  20. czuch az
    czuch az
    Good Lord. Leave em be. I worked at a yard in the 70's. We removed engines and trannys as a unit. Peel the hood back with the yart truck, wrap a chain around the engine and lift and drop till the poor thing just popped out.
    I'll probably smoke a turd in purgatory for those cars I wrecked.
  21. vtx1800
    vtx1800
    Back in the 80's I had a "mini salvage yard" about 50 cars, turned out I was not in compliance with the local zoning laws, I was zoned rural and to have a salvage yard I would have had to be zoned Heavy Industrial, a long interesting story but most of you wouldn't care to hear it. Anyway, I had the cars crushed but they left the gas tanks, wheels and tires and I needed to dispose of those so I used the wheels with tires to burn out stumps, the wheel would be glowing red as the tire burned, those wheels make good hose racks and grinder stands at best.
  22. 73RR
    73RR
    Burning tires?
    Frankly, I'm more surprised that the local EPA clean-air-Nazis haven't shut the place down....
    56don likes this.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    That's what I was thinking , around here , you burn a tire & you'll have 10 black suburbans w/ epa guys in haz-mat suits on your property in minutes !!
    dave
  24. BJR
    BJR
    We would never get away with burning tires around here in Wisconsin, but then this is not the south!
  25. Kiwi 4d
    Kiwi 4d
    Send the rims to the knackers yard for sure. They were only burnt for a reason, scrap value......
  26. i heard about a forge [?] in upstate new york that put tires on rims into a hopper and light it. the burning tires melt the steel.
