I’ve got a bunch of parts where I had wanted a T since I was really little and started buying parts when I was 15 or so. Here’s a partial list: Loaded front juice brake backing plates $75 Early Mustang steering box (short input, rough spot) and 37-‘41 steering box (little gritty but all the parts seem available) $50 ‘42-‘48 spindles? Great shape. Original arms were cutoff for bolt-on arms $50 Sun EB-9A tach controller (dead batt) $35 HMMWV low back bucket seat frames $20 Disassembled Model A front suspension with rough but useable ‘32 spindles (1 leaf broken, missing kingpins and shackles, driver side spindle has steering arm cutoff) $225 F1 15” front steel wheels (2 wheels) $50 Imperial Crown 15” 5 on 5.5” steel rear wheels (2 wheels) $50 55-57 Chevy v8 front motor mounts $20 Steering column 36” overall length $50 Stewart Warner 0-240 degree water temp gauge with little panel $15 ‘50? Dodge or Plymouth pedals $25 Rough ‘31 Model A gauge panel modified to fit 2-1/16” (if I remember correctly) Stewart Warners $20 Guide L2-58 plate light $15 Early pre-'60? Holley fuel bowls (front is actually from a 2-barrel, planned to bore the hole for transfer tube) $5 One inch 4-barrel spacer $1 More parts I can’t remember. Make offers on parts. Will ship small stuff.
Bump. Thought I posted more pictures, I'll take some soon. Got an 8BA block with mains, oil pan, oil pump drive gears and cover, early timing cover, merc bellhousing and starter plate and clutch fork and cover I'm considering selling also. Block does have a small crack that will be a relatively easy fix.
