Building a wheel
Discussion in 'The Hokey Ass Message Board' started by spiertb, Jan 28, 2014.
  1. spiertb
    spiertb
    I've read here about using the center of one wheel and welding it into an wider rim. What is the best way to remove the center from the donor wheel? Thanks. Sylvanus
  2. bobbytnm
    bobbytnm
  3. Hnstray
    Hnstray
    from Quincy, IL
    The link in the above post is excellent. The only thing I would do different is to drill the valve stem hole BEFORE painting the wheel.
  4. big duece
    big duece
    from kansas
    If its an old wheel, drill the rivets out and press/pound out the center. If its welded, you would have to have the welds cut on a lathe.
  5. For drilling out the rivets, I found that using a drill press is the easiest way. Make a simple fixture to hold the wheel.
  6. vtx1800
    vtx1800
    I used a plasma cutter to cut the center out, just another option.
