Projects Building a channeled 32 3 window in new Zealand
Discussion in 'Traditional Hot Rods' started by FE_STEVE, Dec 29, 2017.
  1. budde
    budde
    from nz
    Hello steve . following your build with interest as I too am building a 3 window but its a chev .
    I was thinking of getting some 32 American stamping rails and I like the way you have boxed yours .
    question for you in relation to our cert process is the welding of rails , is this done under compentacy or do they require certed welding . the hotrod hobby car book says I can weld them being a competent welder but ive been told by other rodders I cant .. . what process have you followed here . the only welding that requires cert that I can see is when a the weight of the vehicle is in question . eg suspension . ? thoughts from the south nz .
    FE_STEVE likes this.
  2. Must be time for an update. JW
  3. deathrowdave
    deathrowdave
    from NKy
    Nice build , not my choice to channel it but , it’s yours and your doing top shelf work . Keep it going and keep safety 1st on your build sheet .
  4. 31hotrodguy
    31hotrodguy
