Projects Building a channeled 32 3 window in new Zealand
Discussion in 'Traditional Hot Rods' started by FE_STEVE, Dec 29, 2017.
  1. FE_STEVE
    FE_STEVE
    Reason for using it as I have always used the f1 boxes on my hot rods. The clamp is no different from the flange coated onto the steering box. And with the block of steel I'm able to use the 32 steering box holes in the chassis. And no will not put a Toyota steering box my hot rod.Thanks
  2. MR CLEAN
    MR CLEAN
    FE_STEVE,
    Great start to your Channeled Project!!!
    Thank You for doing a build thread on your Original Three Window Deuce as many will be watching.
    MR CLEAN
    FE_STEVE likes this.
  3. bathcollector
    bathcollector
    How are you going to get around the Cert process building this LHD ?
  4. FE_STEVE
    FE_STEVE
    It has paper work as it was imported from the usa
    kiwijeff likes this.
  5. bathcollector
    bathcollector
    Is it a complete car ?
  6. FE_STEVE
    FE_STEVE
    Rolling chassis with body
  7. bathcollector
    bathcollector
    Cool car, nice F100 too.
  8. FE_STEVE
    FE_STEVE
    20170819_105215.jpg 20170819_135614.jpg 20170819_161121.jpg 20170819_162053.jpg 20170819_162057.jpg 20170819_163527.jpg 20170819_163520.jpg 20170819_163643.jpg So now im boxing the front of the chassis. I have made the boxing plate like a channel and welded the edge to the chassis
  9. 31hotrodguy
    31hotrodguy
    Just came across this build! Totally going to follow this one! Nice work!
    Sent from my SM-G550T using The H.A.M.B. mobile app
  10. FE_STEVE
    FE_STEVE
    Thanks man
  11. Looks tits!
  12. big duece
    big duece
    from kansas
    Glad to see you step boxed the frame rails.
  13. I will be following this with interest. :cool: JW
    surf10 and FE_STEVE like this.
  14. catdad49
    catdad49
    Great start, has an East coast look to it. Nice frame table, too.
  15. FE_STEVE
    FE_STEVE
    Ok so I got the front all boxed. Now to move on to the middle of the chassis. I used industrial chassis dog legs to strengthen the original k member. And did step boxing plates with hole again.
    mgtstumpy, kiwijeff, Tudor and 3 others like this.
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I love the steering solution looks beefy as hell. 360 degrees of grip on that thing. This is gonna be a cool coupe! Following along.
    Tuck
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    ps boxing plates are BITCHEN.
    FE_STEVE and kidcampbell71 like this.
  18. FE_STEVE
    FE_STEVE
    Thanks Tuck
  19. Andy
    Andy
    I wish that torsion tests were run when building frames. It would sure be interesting. I did mine by putting jack stands under the rear kick ups and one under the center of the front crossmember. I held the rear down by hanging a SBC short block from the rear. A board across the front let me apply leverage. Just measure the drop of the front frame horn and calculate the applied torque. I got less than 1/16" with a load at of 800 ft-lbs. Stock was over 2"
    The frame is really a work of art!
  20. FE_STEVE
    FE_STEVE
    Started making the rear boxing plates today as I'm keeping the step boxing plates the same from front to back 20170831_201853.jpg 20170901_132356.jpg 20170831_170155.jpg 20170901_163949.jpg
    mgtstumpy, kiwijeff, Tudor and 5 others like this.
  21. edcodesign
    edcodesign
    Nice craftsmanship, good luck !
  22. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Go man Go!
  23. You're killing me Steve. That's the one I should have kept. You are doing a great job. It is going to be a killer car.
    KKrod and FE_STEVE like this.
  24. Great start - love the steering box mount and the boxing plates. Very nice .....
  25. Cool build, Great metal work. What year Cad motor and what did you use to mount the g/box?Nicest looking stock exhaust manifold also.
    Rhd drive and the starter is a pain alright,ingenious job on the steering box mount.
  26. ss34coupe
    ss34coupe
    Like it. Nice work!
  27. FE_STEVE
    FE_STEVE
    Hey man. Thanks,motor is a 59. Gear box mount is soon. Stay tuned...
    Barrelnose pickup likes this.
  28. FE_STEVE
    FE_STEVE
    Sorry been a slack with the thread. Here's the motor and box setting and start of engine mounts 20170907_210041.jpg 20170911_202025.jpg 20170915_162542_001.jpg 20170906_200952.jpg 20170915_162548.jpg 20170907_182539.jpg
  29. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Can not wait to see more. Nice choice on the Caddy motor.
