Customs Building a '56 Olds Custom
Discussion in 'The Hokey Ass Message Board' started by 2Hep, Oct 21, 2009.
  1. 2Hep
    2Hep
    My '56 Olds Thread.
    Chopped 4" in the front 5" at the rear
    I'll post pictures as I download them.
    Here's a shot of the start of it...
  2. picasso
    picasso
    I love '56 Oldsmobiles, Im gunna watch this.
  3. lowbiz
    lowbiz
    more pics!!!
  4. jasonp
    jasonp
    from Aurora,IL
    My 57 Buick Special kustom
  5. 57JoeFoMoPar
    57JoeFoMoPar
    56 Olds is a beauty. You're starting out with a great looking car. What are your plans for body mods? I'll be watching this thread
  6. hotrodj54
    hotrodj54
    they are one of my favs also
  7. Hope you have the glass figured out. Cool project.
  8. 2Hep
    2Hep
    It was a perfect car to start with. Infact, it's my second '56 88 Holiday that I've owned. Love the lines of this car. Anyway this was a Cali car its whole life. No rust, pretty well cared for. Bought her in Chico, CA and drove her back to Detroit. I never intended to turn this into a project but one thing led to another. It started with leaky dry window seals and the removal of all glass...then beofre Steele Rubber could send the new ones, everything snow balled.
    Started with replacing the dash with a mint dash from a parts car '56 I had laying around...
    pictures coming as with the rest of the story....
  9. choped
    choped
    from Joliet
    my uncle is building a 56 olds, but his was a hardtop turned into a convertible with a scratch built carson top.
    looks cool though cant wait to see more pictures.
  10. Nix66
    Nix66
    from Detroit
    come on show them some more recent pics!! its going to be awesome!!!
  11. 2Hep
    2Hep
    The 1951, '53 GM LaSalle. This is what I'm going for with my build. But I'm trying to keep it late 50's early 60's with out alot of the "fu-fu" (not there's anything wrong with "fu-fu") I just wanted this to be "Styled" and clean.
    ***Pictures are from me when I was at a luncheon at GM Heritage Center
  12. Hotrod95
    Hotrod95
  13. ZZ-IRON
    ZZ-IRON
    from Minnesota
    got to watch your build, cool idea
  14. 2Hep
    2Hep
    Soooo back to the car. The Olds was a daily driver, drove it from Chico, CA across the country and back and forth to work. Dropped it down front and rear, cut 2.5 coils out of the front and had Eaton Springs, spit me out de-arched heavy duty rear springs with reversed eyes to drop it in the rear. Ran big Bias Ply Firestones from Universal Tire with 5"WWW to get her to sit just right.
    (pictures to come- not downloading for whatever reason)
  15. 2Hep
    2Hep
    With that said... Time seemed endless and the chop started to take shape, First I started timidly about only removing 1.5" in the front and 2" in the rear. But that's alot a work for such a small amount of metal being removed...like an old Hot Rodder once told me, "if Yer gonna be a bear, be a Grizzley bear" so came another .25" and another .25" getting the roof sitting right. Roll the car outside then step back 15 or 20 feet and look at...that's when I started to notice that the side trim (which I'm keeping on the car) started looking weird with the new roof line in the rear, so the rear posts started getting lower, to keep that angle set right, when you look at from the side...resulting in a back glass that is like a mailbox slit.
  16. 2Hep
    2Hep
    Due to the angle of the front pillars, pointing forward and wanting to keep the roof profile "Stock" and not lay the glass down, I moved into the package shelf like 3 inches. Wanted the roof from side view to be upright as if I had never touched the roof to drop it.
  17. 2Hep
    2Hep
    My Car before all this happened....
  18. 2Hep
    2Hep
    another before shot
  19. 2Hep
    2Hep
    In these shots... I've got the roof at the rear where it lines up with the side trim (I'll try and get a side view shot to better illustrate it)
    also I sweet inside shot of how low this thing is
  20. 2Hep
    2Hep
    Think of it like a Factory Custom Club Coupe from 1956.... I really dig those early club customs with that short rear quarter window
  21. 2Hep
    2Hep
    Plans for this:
    Chopped Roof, Graphed in '56 98 Taillights, C-notch the rear frame, mount gas tank in trunk on top of frame, rebuilding the engine/trans, cleaning up the firewall for a neater paint job, installing a new brake booster and duals to replace the single manual brake (which was a fun drive through New Mexico, in a blizzard ((see pict)) Interior redo, paint, and a super super sweet engine set-up. If I can locate a Conti kit for the rear I'll extend the rear quarters and make her longer to go with it.
  22. 2Hep
    2Hep
    Western side of New Mexico 7:30 am
  23. metalman
    metalman
    Yup, people think it's all sunshine here in the desert in NM but it can get pretty nasty up around the continetal devide between Gallup and Grants!
  24. 2Hep
    2Hep
    Metalman tell me about it... got into a steep crawl near Gallup. But the Olds Held the course. I was happy though to get back into Texas.
  25. kkoacolonel
    kkoacolonel
    from Union,NJ
    I had a 56 "88" ht.I'll be among the many watchin this.Good Luck!
  26. 2Hep
    2Hep
    Starting to figure out my side scoop, using the stock trim as a template for the opening. Trying to figure out how much of an opening to make it. I want it functional, as I plan on using some air to vent the trunk space for the gas fumes... Just picture a little stainless mesh and some teeth sticking out of the opening. The LaSalle has something real similar and subtle on its rear quarters so that was my go to vision for this mod
  27. 2Hep
    2Hep
    Here I made it alittle too much so I think I'll be backing it down to probably 2" gap.
  28. 2Hep
    2Hep
    The front glass will be easy, like the easy side glass, it's the backglass I need to figure out still.
  29. TikiBoi13
    TikiBoi13
    from San Pedro
    Looks good, like that u drove it home that must have been a mission, but sounded like a cool one. Good look with the bulid and the "back glass."
  30. 56LOWRIDER
    56LOWRIDER
    from Apollo, Pa
    Hello, I curious about what you are in the process of doing. I have been trying to hash out in my mind how to do mine, short of taking the top of another car that has a more graceful flow to it. Mark
