The best Ford intake is the 1957 ECZ 9425-B single 4 barrel. This manifold accepts late style Holley and Carter 4 barrel carburetors. It can be produce up to 325HP. Any of the aftermarket aluminum ones will work good as well. Camshaft: Isky 301444. One step up, the 301333 will give you more of an "idle". I used the 312 supercharger cam in my 272 and it worked great.
http://www.ford-y-block.com/ https://www.google.com/?gws_rd=ssl#q=y+blocks+forever check these places out. lots of info here as well
You should probably get a copy of this:http://www.mre-books.com/ford/engines/102196_y_block.html Y-blocks have a valve lifter that is solids only,never was hydraulic available for the y-block.Also that is not an EZ swap,click on this and scroll down to post #21 http://www.jalopyjournal.com/forum/threads/anybody-got-a-y-block-in-a-shoebox.177373/ This shows the swap step by step with pictures. Also in the aftermarket y-block parts will cost double or triple and more than a later 302 SBF will if you decide to go that route you should stop by here:http://www.jalopyjournal.com/forum/social-forums/1952-59-ford-social-group.282/
It is much cheaper to put a later 302/5.0 Ford in your '53 and there are kits available to do it,if you want the y-block look one of our members has an adapter kit to use y-block valve covers,see below.
