Technical Build Dilemma! Need Pics Please!
Discussion in 'Traditional Hot Rods' started by deuceroadster2, Dec 31, 2016.
  1. deuceroadster2
    deuceroadster2
    I'm looking for pictures of Model A coupes on stock frames that have been Z'd in the rear. If you can specify how many inches the frame has been Z'd and what type of springs the car rides on that would be great too!
    Thanks!
  2. sloppy jalopies
    sloppy jalopies
    not stock A, but flat front 7.5" kick...
  3. 55zephyr
    55zephyr
    Mine has been Z'd the width of the chassis rails and runs the original spring minus 2 leaves.
    Good luck, Ron.
    lothiandon1940 and Paul like this.
  4. deuceroadster2
    deuceroadster2
    Thanks for the replies guys!
  5. cooke
    cooke
    55ZEPHYR- do you have any side shots of your car? We're in the same boat as deuceroadster2,
    I am curious as to how much rake the car has from a side view.
    Thanks for your time.
  6. 55zephyr
    55zephyr
    This is about the best I have at the moment that show how it sits, I've put taller tyres on the back now and I think it has improved the stance a good deal.
    Good luck, Ron. 13522891_507022729501057_7588593850524768289_o (1).jpg 27244438360_24811339a9_o.jpg
  7. panheadguy
    panheadguy
    from S.E. WI
    A typical "Z" of a frame is just the height of the frame rail. Depends on where you cut as to the height change because the frame tapers
  8. cooke
    cooke
    Those pics are good enough to see what I was wanting to see.
    Appreciate you taking the time to post them.
    The car has a real nice stance. Pretty much spot on, IMO.
    It's quite a bit different than essentially the same car sitting right beside it.
    55zephyr and lothiandon1940 like this.
