A totally remanufactured 1960 Buick nailhead engine. Block boiled and machined. .040 over bore. .020 rods and mains. reassembled with new cam bearings and cam, timing gears and chain. Heads are 1966 425 with fresh valve grind. 425 front cover and water pump. and an electronic dist. Features polished Offenhauser valve covers with Moon vents, Valley cover and spark plug covers. A great starting point for your nostalga custom or hot rod. Why be the next guy in line with a small block chevy. (yawn), when you can put this together for about the same cost. Adapters are availiable for just about any combo of transmission you want. $2495.00....... ? Located in Alabama 35126 Will. [email protected] Thanks for looking.
