Technical Buick drum question
Discussion in 'The Hokey Ass Message Board' started by LSJUNIPER, Jul 13, 2016.
Tags:
  1. LSJUNIPER
    LSJUNIPER
    from ct
    Hello, Would like to know what year this Buick drum is.
    Thanks for any info you can give.
  2. LSJUNIPER
    LSJUNIPER
    from ct
    Inside diameter is 12-1/4"
    Outside diameter Is 13-3/4"
  3. porknbeaner
    porknbeaner
    Pre '64, after '64 they were 90 fin. I believe that the first 45 fin Buick drums were in '59.
    OK I was wrong the first 45 fin drums were on the '57 Roadmaster. Then in '58 all Buicks got them. Funny I don't remember my '58 Roadmaster having finned drums. Musta been the drugs. :D
    shown50 likes this.
  4. Andy
    Andy
    Max over size is 12.090".
    It is done.
  5. porknbeaner
    porknbeaner
    As measured with a brake caliper. you left that out. ;)
  6. LSJUNIPER
    LSJUNIPER
    from ct
    OK, Thanks for the info. Is there anyone who makes the parts to put this on a model A? Who would you recommend?? What parts do I need??
  7. RainierHooker
    RainierHooker
    from Tacoma, WA
    Need a little more information than what you've given us.
    If you are planning on putting this on stock Model A spindles, you would need at a minimum:
    1940-1948 Ford "Inside Mounting" Hubs
    1939-1948 Ford Backing Plates (or any of the myriad of aftermarket types)
    A Model-A Spindle to 1939-48 Ford Brakes Spacer Kit
    And a machinist that can adapt the hubs to your Drums
  8. LSJUNIPER
    LSJUNIPER
    from ct
    I am using an after market frame from the Boling brothers, with a new front suspension Pete and Jake's I beam. I don't have the spindles. I am starting from scratch.
  9. oj
    oj
    Check the Wilson Welding site, they have a complete setup, it'll save you a ton of grief and money.
  10. porknbeaner
    porknbeaner
    Yep this is the way to go if you are scratch building ^^^ and you can get those really sexy finned backing plates to boot.;)
  11. Andy
    Andy
    The drum you have is way oversize. Shoes will not fit at all without arcing. Your first priority is to find usable drums. See if the aluminum is about the same thickness as the liner. It should be pretty thick. Like a quarter of an inch plus. Don't buy any drums that are out of spec and don't buy any that have a white line betwween the liner and the aluminum. It is corrosion and can warp a drum 1/4" out of round and ruin it. I did maybe twenty sets of drums back when. I have thrown some away with corrosion from damp locations.
  12. porknbeaner
    porknbeaner
    Lots things to look out for on Buick drums.
    I run 90 fins, usually. Lots of reasons and all of them lame. Anyway the set I have to run are NOS. I got lucky. I also currently have a pair that someone removed the hubs from and didn't do it right. The centers are all cracked. Something else to lookout for on Buick drums.
    Hey Andy while I am thinking about it I went to language school with a fella from Kerrville. I don't remember his name and I don't imagine that Kerrville is that small a place. he and his wife owned a jewelry store.
    Small world ;)
  13. Andy
    Andy
    Mr Beaner,
    You are one I always read and listen too. I would love to meet you sometime.
    The best jewelry store in Kerrville is Bangles Jewelry on Water street.
    Been in there many times as they fix clocks also.
  14. porknbeaner
    porknbeaner
    Next time I am down your way I'll look you up.
    I remember traveling Reynosa with the fella several times to buy belts to sell in the store. I wish I could remember his name. His wife stayed back to mind the store while he went to school.
    Way off topic I guess. :eek:
  15. seb fontana
    seb fontana
    from ct
    Naw...
  16. 29AVEE8
    29AVEE8
    If you are committed to using those drums and the attendant work involved, and can not find usable drums, give these guys a call. It won't be cheap.
    http://www.jgrelining.com/
  17. LSJUNIPER
    LSJUNIPER
    from ct
    Was offered a set of drums with the hub for 600 bucks, worth it? I also took a look at Wilson Welding, didn't see if they offered drums.
  18. Andy
    Andy
    Is the set using the hubs that mount on the outside?
    What is the actual inside dia? Take them to a front end shop.
    Any corrosion?
    Close does not work on brakes anymore than with engine internals. It has to be right..
    I would not use any of the hubs that mount on the inside for many reasons.
    I would not buy oversize drums or any showing any signs of corrosion.
    The liner must not be cut back when clearancing for the backing plates. Cuting the liner makes the shoes hang off the edge.
    29AVEE8 likes this.
