Pretty much complete engine. Tore it down sent to the machine shop, block was bored 30 thou., new cam bearings, heads completely rebuilt. Crank was polished and mic as standard and so did the rods. While the engine was in the shop, I found another engine and went in that direction. I have all the internals as well as intake, carb, exhaust manifolds, etc. The oil pan and valve covers are bent up, also timing chain cover/water pump neck its broken, may be able to repair. Godspeed MrC.
