Hello. After installing a few sets of the 45 fin Buick aluminum brake drums on my Hot Rods with the Buick backing plates, I thought I would post these numbers I have gathered in case they may help someone out. These are part numbers if you are using the original Buick backing plates with the drums. These are all NAPA numbers; Front shoes TS-197 (12" by 2 1/4") (I also use these on the back) Front shoes TS-127 (12" by 2 1/2") (These do not always work, some have different depths where the pins from the cylinder meet the brake shoe) Front wheel cylinder 14493 Front wheel cylinder 14494 Rear wheel cylinder 13388 RT Rear wheel cylinder 13387 LT Adjusting screw 80562 Adjusting screw spring 80503 Shoe link 80743 Spring for rear parking brake cross piece 80744 Maxi pack (springs, pins, cups, misc.) 2225 The maxi pack will give you an assortment of pieces. NAPA tells me that they are not selling some of these pieces separately anymore. When getting wheel cylinders, look them over as the do not always match right to left in style / shape. I usually have them pull down two or three of each and cherry pick a matched set. I use the red return springs from the 2225 maxi pack. Pins should be #1's. I am always willing to answer any questions if I can, just send a PM. I have installed these 45 fin Buick brake drums with the Buick backing plates on early Ford round back spindles and small bearing 9" Ford rears. Got this info from FRAMES: I have been using advance #w13387 and w13388. 1 1/8" 70 ford 1/2 ton. $9.99.
Hey Hotroda, Good info, I fabed Buick brakes on the rear also with 9" bearing ends on my Quick change. The front brake cylinders for the Buick drums, I got a new set off 66 and newer. They have 1/16" bigger bore, pedal effort a little less with the bigger cylinders. I only buy brand new brake parts and cylinders. too many problems with rebuilt. Ago
Hey I want to put a set On my 53' belair kustom can i just slip all the buick gear onto my gm spindles?
Added in the Tech Archives on Buick Brakes - thanks for the research! http://www.jalopyjournal.com/forum/showthread.php?t=166339
This is one way: http://www.jalopyjournal.com/forum/showthread.php?t=91081 Don't know if anymore are avail or not...
I ran into some difficulty with shoes on my most recent (this weekend) 45 fin front set up...sometimes the 2 1/2" shoes will not work. I used the 2 1/4" shoes, they work well. I updated my info above...
