buggy spring replacement
Discussion in 'The Hokey Ass Message Board' started by negativeMatt, Mar 24, 2007.
  1. i'm redoing the rear frame section of my truck. i built it with a tall "z" and used a T buggy spring. well, after adding the bed, i wanna use a spring that isn't so tall. something "flatter" that won't require such huge "z" in the frame so i can have more space inside the bed. i've heard of using 40's era ford car front springs. anybody have any suggestions?
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Sure you can use the front spring of any 35-48 Ford passenger car if the spring mounts you have are spaced properly to fit the spring and you have clearance for the rear end or other bracketry. You may have to remove a leaf or three to get a good ride, but you did on the T spring too, didn't you?
  3. rodrelic
    rodrelic
