Does anyone have a recommendation for a brush on trim adhesive??? I have used the spray can 3M Trim Adhesive and was happy with the results but this project I have some very small and hard to reach areas for a spray can however...IF...there was a brush on adhesive I could dab and dibble some glue onto the panel and the back side of the loose trim piece and get the trim glued down again. As always...THANKS for your help and advice!!!
I just bought this for my Headliner Install, but I haven't used it yet. http://www.ebay.com/itm/161095859434?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT Came highly recommended. For Hard Trim Items, I swear by 3M Double Sided Tape, available at Auto Store and HomeDepot.
Not all double sided tapes are alike in strength of adhesion....not even within the 3M line. Ask your local custom picture framer if they have, or will order, a roll of 3M #969 Super Sticky.
The Weld contact cement in the quart red and white can is what I use.Works great and is easy to get.about 10 bucks a qt.
