Brookville vs Vintique- Grille Shells
Discussion in 'The Hokey Ass Message Board' started by qzjrd5, Dec 9, 2006.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    How do you tell them apart? I bought a used but like new "Brookville" shell from someone off this board, and I asked him specifically whether it was a Brookville part as he claimed it. He said it was. So I went forward with the purchase.
    Today it arrived. Box that it arrived in was a perfectly fitting box that says "Vintique" on it. Hmmm.
    I just want to make sure I got what I paid for. I have never had any trouble at all with anyone on this board before. Is there anyway to know for sure what I have here?
    Thanks!
    Mike
  2. I'm guessing that Vintique doesn't stamp out grille shells.
    It's probably a Brookville in a Vintique package.
  3. qzjrd5
    qzjrd5
    from Troy, MI
    I found this and it makes me think they are different....not sure if Vintique stamps them or they buy them from someone else.
    http://www.rjays.com/32_Ford/32-grilles-01.htm
    But on the other hand, I did a search on the HAMB here and found where the seller had inquired about a Vintique original style unfilled shell and stated that he was thinking about selling his Brookville filled shell. I have his old filled shell I believe. So maybe he bought the Vintique original style unfilled shell, and sent me the filled Brookville in the box that the Vintique one came in. Makes sense.
    Anyways, I'll leave it at that.
    To be honest, I am not even sure the Brookville repo is any better than the Vintique one (I have read some other posts on the subject) but I was looking for an American made shell.
    Thanks. Mike
  4. Deuce Roadster
    Deuce Roadster
    Vintique style ...
    Brookville style ...
    The Vintique has the correct style holes in the lower part of the shell ... and Brookville does not ... :)
    Henry style ... and a 4 inch chopped one :D :D
  5. AA/Fuel34fordpu
    AA/Fuel34fordpu
    Does it matter as long as its a nice piece? I bought a Brookville for my roadster and I like it alot. If I would have known about Vintique beeing cheaper thats the one I would have bought.
  6. peanut
    peanut
    rutlibe does them for brookville. you can get them straight from them too. sorry don't know about the spelling?
  7. 40Vert
    40Vert
    Brookville's is pretty nice, I've used two on my Model A's. I haven't had experience with Vintique's but if I wanted the stock, unfilled look, that's who I'd go with.
  8. qzjrd5
    qzjrd5
    from Troy, MI
    Ok, makes total sense to me now, didn't know about the "hole" thing!
    Looks like its a Brookville.
    Thanks to all that replied.
    Mike
  9. Anderson
    Anderson
    You can get a Vintique shell will all the holes filled to. It may say made in Taiwan, but it's still a pretty nice piece.
  10. Roadsters.com
    Roadsters.com
    Since I still haven't seen one up close, I'd like to see a picture of the side of a Vintique '32 grille shell. Does it have provision for the stock band around the back? (Brookville's doesn't.) Does it have the holes punched for the headlight wires? (Brookville's doesn't.)
    I only use the original grille shells and inserts. Here's a picture of one of them.
    Dave
    http://www.roadsters.com/
  11. Anderson
    Anderson
    Vintique's does have the lip for the hood lacing, and the headlight holes. We just sold the last one in stock at work yesterday, the next one we get in I can get some pictures. It feels like a thinner guage sheetmetal than you'd expect from an original, but I've never held an original in my hands. Otherwise, it's just like stock.
  12. 40Vert
    40Vert
    The Vintique is thinner than original, but still a good peice if you don't have a gennie lying around.
  13. Roadsters.com
    Roadsters.com
    Thanks for that. It's fairly encouraging. People wanting something affordable needed an acceptable reproduction.
    Vintique probably used thinner steel for two reasons: because that makes them easier to stamp; and because being made in Taiwan, the gauge of the sheet metal would be metric and they went a bit thinner rather than thicker.
    Dave
  14. pepi
    pepi
    I agree with AA/Fuel34fordpu , I also purchased the Brookville shell and was satisfied with the quality of the shell. It has a heavy metal feel like the original body parts, nice piece.
  15. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I have used them both. Brookville is heavier although I seem to have a issue with the fit. The Vintique is noticably lighter but is closer to an original one in its style and fit. Can't beat on original!
  16. VAPHEAD
    VAPHEAD
    The Vintique original style one is great.Not filled,slots for windlace.
    Has the mounts for the stainless band.
    The headlight conduit holes are not drilled,but are marked.
    The holes in the splash pan are there too.
    They also make a filled one.
    And to make it more confusing Vintique used to buy theirs from Brookville.
    The Brookville one was great when it first came out,but now compared to the Vintique is sure looks sloppy.
  17. spoons
    spoons
    from ohio
    WRONG!!! Brookville stamps their own.....
    Spoons
  18. mlinton1941
    mlinton1941
    NOTE: the grille sit back in the grille shell ! NOT so good of fit wih anything aftermarket ! MIKE
  19. mlinton1941
    mlinton1941
    NOTE: the grille sits back in the grille shell ! (original) NOT so good of fit with anything aftermarket ! MIKE
  20. Wow, this thread is 12 years old. HRP
  21. big duece
    big duece
    from kansas
    Never a bad time to discuss '32 stuff.
  22. Beanscoot
    Beanscoot
    Might be an opportunity to let people know if the repro grille shells are better, worse or the same nowadays as they were back in '06.
  23. a boner
    a boner
    Does rutlibe make hood sides too?
  24. big duece
    big duece
    from kansas
    I sure like my Vintique with a Dales insert. It has the correct beads around the edges for stainless trim, and stampings for the hood lacing.
    maneri likes this.
  25. big duece
    big duece
    from kansas
  26. Beanscoot
    Beanscoot
    Is the Vintique still made thinner than the original?
  27. bchctybob
    bchctybob
    Spell check; it's Rootlieb Inc. http://www.rootlieb.com/
    Curious whether the repop '32 grille and insert selection has gotten bigger or still just two good sources? Is all of the old info above still good?
  28. Is that a record?
  29. uncle buck
    uncle buck
    Possibly a by product of too much soup of the day? lol
