Brookville Roadster Trunk Drains
Discussion in 'The Hokey Ass Message Board' started by Fast Bill, Feb 21, 2012.
  1. Fast Bill
    Fast Bill
    Has anyone installed the trunk water drains that Brookville sells for their roadster? I'm trying to install mine, but they don't seem to fit. I'm not sure if they need to be trimmed to fit or not. Thanks for any help.
    Bill
  2. wayne-o
    wayne-o
    Do you have a picture of these? I made some sheet metal pieces to fill in the gap on the inside lower corners of the trunk opening and the lower piece. Glued in with seam glue and then drilled a hole for a piece of 3/8" tubing. Flared the end of a short piece of tubing and glued it into the hole then ran a piece of hose off of the tube thru a hole in the bottom of the trunk floor. Hope this makes sense but it worked.
  3. dirty old man
    dirty old man
  4. Fast Bill
    Fast Bill
    Here are pics of the parts I bought from Brookville. Mirror images of each other.
  5. dirty old man
    dirty old man
    Got any nomenclature or part numbers?
    Dave
  6. Fast Bill
    Fast Bill
    Brookville calls them trunk drains. I believe their part number is B169TD. Check out Ebay item # 270775787568.
    Bill
  7. charlieb66
    charlieb66
    Anyone kow if ebay seller "ammuscle" item number above is associated with Brookville, or just sell their parts.
