Auctions
NO LONGER FOR SALE! Brookville '29 Ford Roadster on '32 Hot Rod Chassis
Discussion in 'Cars For Sale' started by missysdad1, Nov 11, 2021.
  1. missysdad1
    missysdad1
    City: Alvarado
    State: TEXAS!
    Price: NO SALE
    I have decided to go in a different direction and have this partially completed hot rod for sale to finance the new adventure. My change-of-heart is your opportunity. Finish it this winter, drive a hot rod roadster in the spring!
    It's an all-steel Brookville 1929 Ford roadster body with all the upgrades mounted on a professionally built 1932 Ford hot rod chassis. All the latches and hinges are installed and a stock height windshield is included. The radiator and shell is stock Model A. A really nice set of '28/'29 fenders with running boards are included if desired.
    It has no motor but was was originally set up for a flathead with Flat-o-Matic with open drive and a '41 Ford rear axle. I replaced that with a small block Chevy as shown in the photos. It is being sold with no motor or transmission. Either a flathead with open drive or a small block Chevy would bolt right back in.
    The chassis is a professionally built reproduction '32 Ford using American Stamping rails with original '32 front and rear crossmembers and a custom tubular X-member from Deuce Factory. Springs are Posies with reversed eyes front and rear. Front axle is 4" dropped with fresh '40 Ford-style hydraulic brakes. Rear axle is '41 Ford converted to open drive with fresh '40 Ford-style hydraulic brakes. All brakes lines are run and include residual valves and an adjustable proportioning valve.
    Hard to see in the photos are the '53 Ford F100 steering box, column and drag link installed after the photos were taken. All the hard work has been done on this car, it just needs to be finished. No motor or transmission is included, white wheels and tires shown in photo come with the car (black wheels/tires available at extra cost).
    Car is sold as a project. Comes with Manufacturer's Statement of Origin for the body, bill of sale for the professionally built reproduction chassis. Never titled. NO LONGER FOR SALE! PM for more information, I will include my phone number with my reply. Please be courteous. I won't waste your time, please don't waste mine.
    new roadster 40.jpg new roadster 32.jpg new roadster 35.jpg new roadster 38.jpg
    69thumper likes this.
  2. missysdad1
    missysdad1
    All the hard work has already been done on this great little old school roadster. It's ready to be completed and enjoyed by a new caretaker. A flathead with open drive or a small block Chevy will bolt right in.
    This is not the usual halfass junk so often offered here in project form, this is a first-class build just waiting to be finished and put on the road. All the heavy fabrication is done and no bodywork or rust repair is needed. Just drop in a motor and transmission and you are on your way!
    Still available as of this writing.
  3. missysdad1
    missysdad1
    This is the best winter project a guy could ask for. All the fabrication is done, and done well. What remains is what a guy could do in his home garage over the holidays and be ready for cruising in the spring. Bolt in an engine/transmission, seat, lights, pedals, gauges and wiring, you're ready to go!
    Still waiting for YOU!
  4. missysdad1
    missysdad1
    Here's the winter project you've been looking for. All the hard work is already done, just needs the finishing stuff like lights, wiring, paint and upholstery. Ready to bolt in either a flathead or a SBC. Great opportunity for a budge-minded rodder. PM for more info.
  5. missysdad1
    missysdad1
    Here are a few more photos. These are older photos and do not show the F100 steering box, column and drag link that are now installed and working. PM for more information: please leave you phone # and I'll call you back. Thanks! NOTE: Engine and transmission NOT INCLUDED!
  6. missysdad1
    missysdad1
    All the hard work is done on this car! It's ready for you to make it your own with your engine, transmission, wheels, tires and paint. Perfect winter project! Brookville body means no bodywork is required and there's NO RUST to deal with. How much better can it get? Still available!
  7. missysdad1
    missysdad1
    Best quality parts, pro-built hot rod '32 chassis ready for SBC or flathead/automatic, new Brookville steel body with all wood included. Great winter project because all the hard work has already been done. PM for more info. Still available.
  8. missysdad1
    missysdad1
    What a great winter project this is. All the hard work has been done and all that remains is to make it your own. And...since you will be adding the "personal touches" such as engine choice, transmission choice, paint color, upholstery material and color, gauges and steering wheel you won't be paying for stuff you'll be changing out during your build. It's perfect for a new or semi-experienced builder. And...it's still available.
  9. missysdad1
    missysdad1
    Quite a bit of interest in this great winter project roadster, but nobody's pulled the trigger yet so it's still available. Choose your own upholstery color, paint color and power train, the rest is pretty much done for you already. So...what are you waiting for?
  10. missysdad1
    missysdad1
    You could be a "roadster guy" in the spring with this well-engineered roadster project. Brand new Brookville body requires no work, the '32 frame is completely done and painted. The brakes are done and meticulously plumbed, the F-100 steering is in place and operating as it should. You won't have to "fix somebody else's f-ups" with this one, just complete it the way you want. It just doesn't get much better than that. Still available, price reduced for quick sale.
  11. missysdad1
    missysdad1
    Lots of closed car projects available but doggon few nice traditional roadsters that are this far along. Engineering, workmanship and parts are first-class, not fabbed-up junk or recycled rust buckets. And, you can finish it as a traditional flathead-powered car or an updated SBC/4-speed car. So...what's keeping you?
