i was thinking about making some bronze shaackle bushing to run my model a shackles with my 32 ford spring... has any one done this before? will they wear hard? thanks
yeah i was just going to spin them in my lathe i have a piece of oilight bronze 7/8 laying around the shop... thanks guys!
'twas nothing... when you don't have a life, or anything else to do but hang around here all day. lol
I made a set for my 40 Ford in 1978 and they are still holding up just fine. I just used bronze bar stock that I had. Never thought about oilite. They don't squeak or deteriorate as rapidly as rubber.
My dad and I built a set of bronze bushing for my Scout. They worked surprisingly good. We built shackle bolts with grease passages and zirks too.
I've made them for a '34 Packard before. That car used a Bijur lube system so you might want to drill and tap for grease fittings if you go with bronze. Shawn
Not a '32 guy, but these look trick for leaf spring applications. Can anyone supply the dimensions of the ones in the first picture?......o.d., i.d., length, etc. I used delrin (sp?) plastic in my Willys. A shot of wd40 occasionally, good to go.
I have had a set on my 32 for 20 years. Work fine and don't squeek of fall apart. I got flanged oil lite bearings from a bearing supply store. 1" OD flange with a 3/4" OD body and 1/2" bore. 1" long.
