Projects BRIAN MADE ME DO IT
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Nov 6, 2017.
  1. DDDenny
  2. What happens when you get the edges so thin they won't carry 100 amps let alone 500 amps. ??
  3. Blue One
    Blue One
    from Alberta
    o_O What’s all this talk of 100-500 amps capacity nonsense :confused: :D
    Are you guys secretly adding arc welding generators into your cars? :D
    As far as I know most auto electrical systems are nowhere near that much amperage.
  4. Bandit Billy
    Bandit Billy
    Doesn't a perfectly running high torque mini starter have the capability to pull over 200 amps?
    31Vicky with a hemi and loudbang like this.
  5. I'll bet you that your battery has something close to 500 cold cranking amps.
    Every engine is different and every starter is different but pulling 300 amps plus on a performance engine is pretty standard operating procedure. Let something get out of whack, heat soaked, or anything else that happens to hotrods and the amps go up from there.
    Yes It's short duration.
    Bandit Billy and loudbang like this.
  6. Blue One
    Blue One
    from Alberta
    Ah yes short term cranking amps. I see :D
  7. Bandit Billy
    Bandit Billy
    For an extra 20 bucks I'd rather be safe than real, real sorry.
    loudbang and 31Vicky with a hemi like this.
  8. flynbrian48
    flynbrian48
    Wowza! That's stunning. :cool:
    loudbang and Bandit Billy like this.
  9. tb33anda3rd
    tb33anda3rd
    1. Connecticut HAMB'ers
    i hate connections in the middle of a battery cable. i think i would just plan to disconnect it at the solenoid [10 extra minutes?], for that most likely, odd time, that you decide to remove the body.
    loudbang, Dick Stevens and greaser like this.
  10. Bandit Billy
    Bandit Billy
    Agreed completely, if that were possible. But that 1 gauge wire has to be run outside the body as there is no room inside for it once it gets tot he door jamb. I don't like cables tied to the frame rail personally so I have hidden mine under the car's channel. It must move inside the car after the door opening though and that requires bending a rather large cable (not going to happen) or some type of bulkhead terminal.
  11. Bandit Billy
    Bandit Billy
    Considering the source, I take that as the highest compliment!
  12. Blue One
    Blue One
    from Alberta
    I’m not going to be able to hide my battery cables that way so I’m trying to come up with some ideas on routing them along the frame.
    The main issue I envision is that #2 welding cable is not stiff and will sag between mounting clips.
    What to do :confused:. Hmmm :D
  13. Bandit Billy
    Bandit Billy
    Before I opted for my solution, I was facing the same dilemma. One idea was to run the power cable inside a stainless tube (polished of course). Number 2 cable is .378 diameter, so a run of 1/2" tube will make it easy to push the cable through, a little WD40 wouldn't hurt. It would look a lot tidier than a droopy cable. The tubing would be easy to bend without crimping with the cable run inside it too.
  14. Blue One
    Blue One
    from Alberta
    Not a bad idea, the only concern I might have would be the end of the tubing cutting it's way through the insulation and causing a short out at some time.
    Wonder if there are any other similar solutions.
    Having a sealed rectangular tube frame I don't have the option of going inside that.
  15. DDDenny
    Black PEX tubing.
    It wouldn't look too bad if available in straight sections to eliminate sagging, it's ridgid and non conductive. Not sure how you would deal with bends, maybe use the coiled type.
    Example
    Looks like the 5/8" has a .584 I.D. perfect for 1/2" cable.
    Edit
    Note the true O.D. differs from the call out dimensions.
    https://www.pexuniverse.com/pex-tubing-technical-specs
  16. Bandit Billy
    Bandit Billy
    Nah, just hammer a flair in the end. Think stainless spark plug wire looms. Same idea.
    Tim and loudbang like this.
  17. Much easier to pull than push
  18. Blue One
    Blue One
    from Alberta
    Since I’m using cunifer (nickel copper) for my brake and fuel lines I wonder if you can get it in 1/2” ?
    It would look good and bend nicely too.
  19. tb33anda3rd
    tb33anda3rd
    i built a 31 chevy, a whole lifetime ago, and before i boxed the frame i tacked a length of 1"emt to the inside of the frame and bent both ends in. i drilled the boxing plates [big] and slid them over the ends of the tube, welded them [filling in the big space around the tube] then cut and ground them flush. i did this on both rails and could fish wires through. i know it is too late for this build but i wonder of it could be done with the flexible conduit, used by electricians, for an existing boxed frame like in Larry's situation?
  20. tb33anda3rd
    tb33anda3rd
  21. Blue One
    Blue One
    from Alberta
    Another interesting solution however for my frame there’s no way I could get anything from one end to the other inside the rails because of the large angled holes I built into the frame for my exhaust to pass through.
    On top of that there’s a very large number of pieces of mig wire sticking out inside them from fabrication of the frame reveal and also the curving of the frame. :D
  22. loudbang likes this.
  23. Bandit Billy
    Bandit Billy
    I hate straightening heavy tubing (anything over 3/16). I needed a straight 6 foot piece of Stainless 3/8" and summit delivered it to me the other day. Beats rolling it out on the floor.
    I think this would be a cool alternative to a long run of red cable under the car.
    I was at the shop the other day to yak with the owner, he had a hot rod on the lift so I got to walk underneath and see her underpinnings. Nice car on the surface, I'd been embarrassed to own what was underneath. Not saying every ones car should be a show car but they should at least be good cars.
  24. Blue One
    Blue One
    from Alberta
    I'd agree with that, at least clean tidy and functional.
  25. Bandit Billy
    Bandit Billy
    Exactly! It would be silly and a waste of resources to take it any further than that.
    loudbang and RICH B like this.
