Guys (or gals), I want to use a piece of solid brass rod, 12" long X 3/4" dia. for my shift shaft. I was wondering if I am ok tapping it to 14mm (approx 1/2" dia) on one end about 2" deep and threading it to my T5. I will have 1/8" of material left on the wall. Is this enough? I have a brass gauge pod so I want to bring it out by using the brass rod. Thanks.
I took a stock S10 shifter and had a blacksmith heat and taper the tiny stub WAY out, then I bent it to where I wanted it. I'm gonna use an antique brass door knob. Only photo I could dig up quick.
Of all people...This is where I got the idea. http://www.discovery.com/tv-shows/outlaw-garage/videos/jesse-james-jesses-home-shop/
Cool video. Hum.....that may work. I have a few blacksmiths in the area. Did you take yours apart like he did?
How about finding a shaft that has the taper & bends already in it, then brass plate it. Polish and clear-coat
Well I found a piece of brass 3/4 X 12" on ebay for $16.00 free shipping. Not sure brass plating would be any less and I have access to a lathe so with a little effort I think I can knock it out. My concern was how solid it would be after tapping out to fit the existing shaft. One HAMBer said 1/8" wall should be enough. Guess I will try and find out.
