Hot Rods Brake Vacuum
Discussion in 'The Hokey Ass Message Board' started by greg37, Apr 10, 2019.
  1. greg37
    greg37
    from mi.
    Hey everyone, I have a 327 in my 32 Ford running 3 Rochester carbs, My question is the vacuum port on the center carb with a " T " fitting drawing enough vacuum to operate the power brake booster mounted on the frame and the PCV valve ? Their is another port on the manifold but it goes to the modulator on the Trans. Engine has a small cam nothing wild. Thanks
  2. Mr48chev
    I'm thinking that there is a factory Chevrolet Vacuum T that fits on that #8 runner that splits the vacuum to the booster and modulator. That may not have more vacuum but it might have a more consistent vacuum level.
  3. theboss20
    theboss20
    Might also consider a vacuum reserve can that can provide extra vacuum on demand...
    Sent from my iPad using Tapatalk
  4. greg37
    greg37
    from mi.
    #8 runner ?
  5. morac41
    morac41
    You might consider a separate constant electric vacuum pump.when the ignition is activated
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    MR48CHEV has the right idea find the factory tee has a 3/8'' port on one side and an 1/8'' on the other side goes on the back of the intake.
    KK
  7. greg37
    greg37
    from mi.
    Okay I'll try that but which one goes to the trans. and which one to booster ? I did see that port on the back of the intake but only has one 90 deg. fitting going to trans. Thanks again
