Brake shoes - which direction ?
Discussion in 'The Hokey Ass Message Board' started by Johnnyzoom, Jul 2, 2009.
  1. Johnnyzoom
    Johnnyzoom
    from Florida
    Can someone please answer the question, at least generally- Which direction does the larger brake shoe face!? I've been getting multiple conflicting answers from manuals to websites. Car in question is 64 Comet, drums all around, manual.
    Thanks for any info!
  2. hotrodj54
    hotrodj54
    ive allways put the bigger shoe tward the back................john
    F-ONE and jaracer like this.
  3. Tony
    Tony
    Yep..
    Primary shoe (short one) in front, secondary (long) at the rear...
    Get's real interesting when they are both the same size....man, i spent hours trying to figure that one out! :D:D
    F-ONE and X-cpe like this.
  4. Ice man
    Ice man
    Larger shoe always to the back, the front shoe is like a floater, and made of different material. It forces the other shoe into the drum because of the rotation and you have servo brakes. Ice man
  5. 66 Belle
    66 Belle
    You have a primary and a secondary shoe. Primary is long pad and secondary is short pad. Long is to the back and is considered primary because of the auto-adjuster. short is front shoe
    F-ONE likes this.
  6. Johnnyzoom
    Johnnyzoom
    from Florida
    Not to be a jerk, but see what I mean? Without knowing any better, I thought the longer shoe would go forward, that it had more stopping power . Thanks for clearing this up for me, and at the usual HAMB speed, fast!
    F-ONE and mrspeedyt like this.
  7. time to get a manual,library is good place to start.
  8. Hans Buscher
    Hans Buscher
    easy to remember...
    B O B
    Big On Back.
    F-ONE and Elcohaulic like this.
  9. Johnnyzoom
    Johnnyzoom
    from Florida
    Thanks, dude, this is from the original manual:
    mrspeedyt likes this.
  10. Looks to me like the manual is wrong.
    (It happens - I have one that lists 25# or so torque on an FE rear main bearing.)
    Refer to other manuals.
    Preferably a Motors Manual or factory manual.
    Short shoe in front . . . because it's the "self-energizing" shoe.
    The front shoe tries to jam itself into the brake drum - which makes it the stronger shoe braking-wise - when the brakes are applied so it's smaller to match the power of the larger secondary shoe.
    Take note of some drum brakes that have double wheel cylinders, top and bottom, both brake shoes are self-energizing and the same size.
    Makes for a nice brake setup, kind of a poor mans power brakes deal, only catch is they need to be properly adjusted.
    Not hard to do once you learn the drill.
    turboroadster likes this.
  11. tommy
    tommy
    I don't know what manual this picture came from but it sure looks like the drivers side to me. I can't think of any car that has the brake cable come in from the rear. My guess is that it is a typo or someone confused the pictures while editing. If the caption was changed to say the passenger side then that would make sense.
    I've worked in or owned a brake shop for over 25 years. I dare say that I have been involved with more brake jobs than most here.
    Compare this exploded view with your picture. You can see that the short shoe (primary or leading shoe) goes to the front as everyone has stated.
  12. panic
    panic
    The self-actuating shoe is the primary, leading or active shoe.
    In some cases it's the same length, but you'll notice the upper corner near the cylinder is beveled back as an anti-grab fix (the secondary, trailing or passive shoe will never have this).
    That book is correct... if it's a RHD car (England, Japan).
    More on double-acting brakes, read my article: http://victorylibrary.com/brit/2LS.htm
  13. cabriolethiboy
    cabriolethiboy
    Is it the same with non self energizing early Ford brakes?
  14. tommy
    tommy
    No it is not! Early Fords are the exception to the rule.
    Good point. I saw the XK and XL models but it never dawned on me that it could be an import diagram.
  15. Billet
    Billet
    Geez aint this shit fun. The answer is...It depends on what type of brakes you're working on. And after all that Your comet has that Fancy self adjuster on the bottom stick the short one in the front.
    Now HAMB me that Grenade!
    Good Luck-
  16. Johnnyzoom
    Johnnyzoom
    from Florida
    Thanks for the help. The diagram is from the 64 shop manual, it doesn't cover imports, it's been very accurate, and I wanted to consult some experts before I digressed from it. Brakes are too important. And yes, this shit is fun.
  17. 1oldtimer
    1oldtimer
    nope, primary shoe is in fact the short shoe......and it goes toward the front of the car.
  18. Larry T
    Larry T
    If you'll look at the emergency brake set up, you'll see this is the right hand side brake assembly. Unless the emergency brake cable comes in from the rear.
    Back to work,
    Larry T
    X-cpe likes this.
  19. barry2952
    barry2952
    Bringing up a necro-thread.
    Working on my '41 Ford pickup and found that the PO, (and POS), that owned this had a self-destruct of the emergency brake mechanism and simply didn't replace it. However, he did wire the end of the cable to a fixed object so that the emergency brake on the other side worked. Can you imagine if I had tried to use that if the hydraulics failed?:eek:
    Anybody have the missing parts they'd be willing to sell?
    I thing the wheel cylinders are backwards, too, as this is a picture of the driver's side.
    Passenger side, for reference.
    RollinRock likes this.
  20. V8 Bob
    V8 Bob
    The primary is always the forward shoe, but not always the longest lining.
    The diagram is mislabeled. It is the right rear brake.
  21. johnny bondo
    johnny bondo
    from illinois
    on that picture its right. the "hand brake" lever is in the back, so the cable is coming in at the front. so this is the rear passenger side. long pad to the back.
  22. barry2952
    barry2952
    My '41 Ford has wheel cylinders that have two different bores. Isn't the larger bore supposed to face forward?
  23. V8 Bob
    V8 Bob
    Yes. The '39-'48 Ford LockHeed non-servo brakes have the longer primary lining forward, along with the larger wheel cylinder bore.
  24. barry2952
    barry2952
    Wow, that's the opposite of what the instructions that came with the shoes said, but I'm intently listening. Please expand on that, as that's counter to what many here have said.
  25. I used to like the cars that came in for brakes, with the 2 short shoes on one side and the 2 long ones on the other side.
    It was always an adventure taking a brake drum off and seeing how creative some "mechanics" got with drum brakes.
    Bob
  26. johnny bondo
    johnny bondo
    from illinois
    smaller diameter cylinders have more mechanical advantage so it makes sense.
  27. V8 Bob
    V8 Bob
    Just the opposite- larger diameter wheel cylinders have more mechanical advantage.
  28. Mr48chev
    No the primary aka front shoe is always the short one or the one with the least amount of friction material.
    The secondary or rear shoe always has the most friction material.
    Some discount brake reliners use the same size lining front and rear but use different friction material. At least one used to use the same size material but had a groove cut down the middle of the lining but I haven't seen any of those in over 30 years.
    Actually on Bendex brakes the primary pushes the secondary around as the it/they rub against the drum.
  29. flyin54
    flyin54
    from modesto ca
    My auto shop teacher (back in the early seventys) told us to always " drag the big shoe"
    osut362 likes this.
  30. V8 Bob
    V8 Bob
    No, NOT always. Non-servo brakes, like the old Ford LockHeeds, have the longer primary shoe lining towards the front. With duo-servos like Bendix and others, the primary front shoe has the shorter lining.
    Some knowledge of what design brake you are working with is important before you assemble it.
    tb33anda3rd likes this.
