Technical Brake plumbing help, please!
Discussion in 'The Hokey Ass Message Board' started by Ritzy1, May 30, 2019.
  1. Ritzy1
    Ritzy1
    OK, I bought a Speedway 11" disk brake kit for '37-'48 Ford spindles (PN 910-31945) thinking it would bolt into my '48 Ford Tudor Sedan. OK, ok, stop laughing! Suffice it to say that I am stumped trying to match the brake hose that came with the kit to the original tee on the driver side. I believe the thread on the female end of the original hose was 7/16-24 as was the original banjo bolt that went through the tee. The new hose has a 3/8-24 IFF female end. I ordered a new banjo bolt with 3/8-24 thread for a .425" banjo height (about the same as original) hoping that would be the fix. Wrong! The bolt has the wrong flare at the bottom and the shoulder is smaller than the original banjo bolt. I have yet to be able to locate a suitable tee that I could use as a replacement. I am using 3/16" hard line with 3/8-24 IF fittings.
    Original tee and hose:
    New hose and new banjo bolt that proved to be wrong flare and shoulder size:
    New banjo bolt I tried that didn't work:
    This is the latest thing that's keeping my car from being on the street. Looking for advice on getting this last piece of the puzzle solved. Thank you in advance for any advice to help me get this safely plumbed!
  2. King ford
    King ford
    from 08302
    Greetings Ritzy1 ! I believe the rubber brake hoses you have will accept the flare nut and flare on the end of readily available steel ( or some less likely alloy) brake line carried by any auto part store what you will need is a TEE with the same thread and flare and do away with the banjo fitting completely...your local auto parts store SHOULD still Carry those as well....but then things ain't what they used to be, if not available locally try speedway or jegs etc.
  3. squirrel
    The original banjo Tee fittings are neat if you are using all original stuff...but yeah, that's what we do nowadays, is get rid of it and replace it with 3/16 inverted flare fittings and associated Tees.
    The original banjo fitting didn't seal at the center, it sealed with washer, to the hose.
    Russco and 31Vicky with a hemi like this.
  4. Ritzy1
    Ritzy1
    Yup, I've looked at the various tee fittings but am still struggling to understand how to connect a female tee to the female hose end. Anybody have pictures of how they made it work?
  5. Replace the banjo tee with a regular tee and then run a short steel line over to the original hose bracket and new hose. Might be easier to make a couple new lines and move the tee further from the hose bracket to make it easier to run the new line.
    squirrel likes this.
  6. That banjo bolt could be machined to look like the original
    Maybe the correct bolt is available
    Clean up the original banjo bolt and use it
    Or get another style tee
  7. Ritzy1
    Ritzy1
    That may be what I need to do. Thanks.
  8. squirrel
    sorry I wasn't as clear as that...I guess things that are obvious to some of us, aren't obvious to others of us.
    Ritzy1 and RICH B like this.
  9. Ritzy1
    Ritzy1
    Thanks for all of your input. As I said, novice here.
    So, for the heck of it I took my puzzle by a local hose shop. The guy at the counter had an idea. He grabbed a -3 AN to 3/8-24 IF adapter and said he could cut off the AN side of the adapter and the 7/16 female side of the original style hose and solder them together to make an adapter to mate the new hose with the old tee and banjo bolt. I think it came out pretty nice. Now to see if it all plays nice together without leaking . . .
  10. mkubacak
    mkubacak
    Looks like too many fittings and adapters. That will just be more opportunities for leaks and problems. I would just get a different Tee fitting and minimize potential problems.
    beater32 likes this.
  11. squirrel
    soldered together? uh....no thanks. If it were TIG welded, sure.
    RICH B, Blue One and 57 Fargo like this.
  12. This seems like a case of over complicating a situation...
    Blue One likes this.
  13. Ritzy1
    Ritzy1
    Yup, probably overcomplicating it. I'll see about making it simpler.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  14. Bolt head/ washer/tee/washer/ hose
  15. Hemi Joel
    Hemi Joel
    from Minnesota
    Did his name happen to be Rube Goldberg? :p If he used silver solder, it should be strong enuff. But do you want to risk your car, your health, and your life on it? If he used plumbing solder, no way should you risk it. Squirrel offered a simple solution, you should go with it.
  16. Ritzy1
    Ritzy1
    OK, going the simple route per everyone's advice. Think I'm going to use a different hard line though, as the stuff I got from Speedway doesn't seem to want to flare nicely. Bought some coated steel line from Autozone and that seems to flare much better.
    Original tee with 3/8-24 adapters and bracket.
    New tee without adapters and Speedway bracket for hose. Still need to plumb line from MC and add line clamps.
    31Vicky with a hemi and RICH B like this.
  17. Happydaze
    Happydaze
    That works.
    Chris
