Hey guys, i'd like to run my line to the right front brake along the firewall on my 55' but it would be above the MC as it goes to the passenger side. Is that going to give me problems with air? If i thoroughly bleed the lines should that take care of it? Posted using the Full Custom H.A.M.B. App!
If you get bled it shouldn't be a problem. Definately will need a residual valve at the master cylinder.
Im thinking this should work. The line is below the top of the fluid in the MC... Not by a bunch, but it is below. Posted using the Full Custom H.A.M.B. App!
