Brake lights wont work, yet night lights work just fine. replaced the brake light switch, checked wires, did bulbs, any suggestions? i may need the connector from the brake switch to the wires.. anyone have anything that will fit?
is there power to one side of the switch full time and power to the other side only when you push the pedal? take a 12 volt test probe and go through the entire brake light circuit
If you have power going into and out of the brake light switch the problem could lie in the turn signal switch. Put on your turn signal and step on the brake, if the stop light works it's in the turn signal switch...
