Technical Brake guru's
Discussion in 'The Hokey Ass Message Board' started by coilover, Feb 16, 2020.
  1. coilover
    coilover
    from Texas
    Problem: brake builds pressure and locks up front disc brakes on 1937 Buick Special.
    Tried so far:
    New rubber lines (twice)
    New master cylinder with factory residual pressure brake line seats COMPLETELY REMOVED
    ZERO inline residual pressure valves. Did have 2# to discs and 10# to drums.
    Rod from pedal to booster has 1/4" free travel
    Rod from booster to MC has 1/4" free travel
    When cold pedal is only 1/3 of its travel off floor
    Kit is from Scarebird and uses Riviera rotors and Astro calipers.
    Brakes are perfect for first half dozen stops and then build till pedal is solid with no free travel and drag old straight eight engine down to a stand still.
    Only part not replaced is 7" dual diaphram booster.
    System worked fine for thirty years with drum/drum configuration.
    HELP!
  2. My brother's 57 Pontiac once did this. After checking everything I finally removed the master cyl and put it on the bench.........found the return port in the master had some gunk in it. Cleaned it out and voila! Worked fine then.
  3. alchemy
    alchemy
    Is something heating up while you drive for a while? Is there a line near the exhaust somewhere?
    bchctybob likes this.
  4. David Gersic
    David Gersic
    from DeKalb, IL
    You’re losing 1/2” of travel in the pushrods and it still works?
    Is it locking both wheels or only one? Crack a bleeder, see if it releases.
  5. I'd start loosening things to find the last place the pressure releases. How did you figure the 1/4" between the master and booster?
    Sent from my Nexus 5X using The H.A.M.B. mobile app
    KJSR likes this.
  6. 67drake
    67drake
    from Avoca WI
    Did you try contacting Scarebird? He is usually pretty good on follow up help.
  7. Pat Thompson
    Pat Thompson
    Wheel bearing too snug? Not allowing piston to be pushed back in caliper.
  8. bill gruendeman
    bill gruendeman
    Is the caliper sticking and not moving back in so the pad stays on the rotor?
  9. what do you have to do to get them to release? does opening the bleeders solve the issue?
  10. earlymopar
    earlymopar
    This symptom is most often caused by the piston in the cylinder not returning and therefore blocking the port. This is often a result of the push rod adjustment not being correct. Re-check your free-play setting but I'd start by backing the push rod off completely (no engagement of the push rod by the pedal arm) to allow the piston to return.
    - EM
