Hot Rods brake fluid
Discussion in 'The Hokey Ass Message Board' started by cycledelicjohn, Jul 15, 2016.
  1. cycledelicjohn
    cycledelicjohn
    IS THERE ANY SIMPLE WAY 2 TELL IF U HAVE DOT 3 OR 4 - OR SIMPLY 5 IN YOUR EXISTING BRAKE SYSTEM WITHOUT A CHEMICAL ANALYSIS ???
    270dodge likes this.
  2. Unscientific way is DOT 3 and DOT 4 will ruin paint.........
  3. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    The silicone DOT 5 I have used is colored purple.
  4. jkeesey
    jkeesey
    Take a small amount of what you have in the master and mix it in a glass with dot 5 in it. If it looks like salad dressing and doesnt mix you have dot 3.
  5. 19Fordy
    19Fordy
    DOT 3 and 4 are compatible. Just don't mix any DOT 5 in it.
    You probably already know this.
  6. Gene Boul
    Gene Boul
    Count the dots!
    Seriously, take a syringe and suck out whats in the MC reservoir and add what you want. You might add "the new stuff" and repeat as above then go forward with the new juice...just saying!
  7. DO NOT do this! If it has DOT 5 and you add 3 or 4 (or vice versa) the remaining fluid in the limes and calipers/wheel cylinders will not mix and they will at minimum become gummy and loss of brakes is eminent. Really bad idea.
  8. vickckik
    vickckik
    Take the car to a service center like Jiffy Lube and have the brake system flushed and filled with the type fluid you choose. They will generally charge about $100.
  9. yellow dog
    yellow dog
    from san diego
    DOT 3,4 and 5 have progressively higher BP's. Look them up if you want to check using the BP
    method.
    Since DOT 3 and 4 are compatible, no problem. They are also good absorbents for water. DOT 5
    is not miscible with water which is its disadvantage. Sample some of you MC fluid and add
    a small amount of water in a transparent container....watch the interface layer. If it the layers stay separate, its DOT 5
  10. jcmarz
    jcmarz
    from Chino, Ca
    I usually go with these dots
  11. Morrisman
    Morrisman
    from England
    3, 4 and 5.1 are the same type, but 5 is some synthetic silicon stuff that doesn't damage paint, but DOES eat rubber.
    God only know why they numbered 5.1 like that. I bought some for my Sportster, after the store dork told me "It is virtually the same as 5". No, dork, it is totally different.
  12. yellow dog
    yellow dog
    from san diego
    DOT 5.1 has a 10*C higher BP than DOT 5.....apparently numbered solely based on BP
  13. Morrisman
    Morrisman
    from England
    So why not DOT 3, then DOT 3.1?
  14. manyolcars
    manyolcars
    Do you have any PROOF that this is true?
    I have proof that this is NOT true. I poured some 3 and some 5 into a container and have been watching it since Christmas. No gummy yet!
  15. manyolcars
    manyolcars
    This is DOT 5s advantage! Not disadvantage
  16. 325w
    325w
    from texas
    Miscible ? At 71 yrs old that's a first for me.
  17. manyolcars
    manyolcars
    think of it as mixable but misspelled :)
  18. kma4444
    kma4444
    I use 5 in all my project cars, have for years. Have always put it in from an empty system. Works well, doesn't affect paint, which is why I use it. Never had any rubber failures with it.
  19. yellow dog
    yellow dog
    from san diego
    DOT 3, 4 and 5.1 are specifically intended to absorb water. Since the MC breaths atmospheric air
    laden w/ varying amounts of water, unabsorbed water is now susceptible to freezing in cold
    winter months.
