I am using a SSBC prop valve . I want to plug one of the front outlets and just use one brake line on the front. It is a 3/8 x 24 fitting . What should I use to plug it ? Thanks , Bill
Should be caps and plugs available that have the inverted Flair sealing surface. Most of the ones I see are pipe thread & you need a fitting pipe to brake line to jump off from. For those you use a pipe plug
